Ir para o conteúdo principal
Western Digital My Book Mini USB Port Replacement
O que você precisa
  1. Western Digital My Book Mini USB Port Replacement, Mini USB Port: passo 1, imagem 1 %32 Western Digital My Book Mini USB Port Replacement, Mini USB Port: passo 1, imagem 2 %32 Western Digital My Book Mini USB Port Replacement, Mini USB Port: passo 1, imagem 3 %32
    • Start by turning the device port side up.
    • With the plastic opening tool, pry along the edges of the case.
    • When you hear the case snap-out of its fitted grooves, slowly slide the board assembly out of the case.
  2. Western Digital My Book Mini USB Port Replacement: passo 2, imagem 1 %32
    • Gently pull the three pronged, clear plastic piece from the rubber holder.
  3. Western Digital My Book Mini USB Port Replacement: passo 3, imagem 1 %32
    • Unscrew the two screws from the motherboard.
  4. Western Digital My Book Mini USB Port Replacement: passo 4, imagem 1 %32
    • Remove all the rubber pieces from the four corners to unhinge the motherboard.
  5. Western Digital My Book Mini USB Port Replacement: passo 5, imagem 1 %32
    • Remove the motherboard.
    • Set aside in a safe anti-static location.
  6. Western Digital My Book Mini USB Port Replacement: passo 6, imagem 1 %32
    • Grab the mini USB port and align it with the appropriate metal docks on the motherboard.
  7. Western Digital My Book Mini USB Port Replacement: passo 7, imagem 1 %32
    • Soldering irons can get HOT! Do not touch the iron tip, make sure it cools down for a good 30 minutes before touching the tip.
    • Start heating up the Soldering Iron, may take about 10–15 mins.
  8. Western Digital My Book Mini USB Port Replacement: passo 8, imagem 1 %32
    • Solder together the four corners of the mini USB to the appropriate metal pieces on the motherboard.
    • Make sure the USB is firmly attached to the motherboard.
Conclusão
To reassemble your device, follow these instructions in reverse order from step 8.
8 outras pessoas executaram este guia.
Gabriel Rael
Membro desde: 06/24/15
333 Reputação
Autoria de 1 guia
Equipe
Colorado Springs, Team 1-2, Mcmichael SU 2015 Membro de Colorado Springs, Team 1-2, Mcmichael SU 2015
UCCS-MCMICHAEL-SU15S1G2
2 Membros
Autoria de 2 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 4
Últimos 7 dias: 31
Últimos 30 dias: 122
Ao todo: 18,460
