Ir para o conteúdo principal
Westcott iPoint Evolution Outer Casing Replacement
O que você precisa
  1. Westcott iPoint Evolution Outer Casing Replacement, Outer Casing: passo 1, imagem 1 %32
    • Step 1: Start with the back of the pencil sharpener facing you.
    • This allows you to locate the power source.
  2. Westcott iPoint Evolution Outer Casing Replacement: passo 2, imagem 1 %32
    • Step 2: Grab the end of the plug located at the bottom of the sharpener and pull it out gently.
  3. Westcott iPoint Evolution Outer Casing Replacement: passo 3, imagem 1 %32 Westcott iPoint Evolution Outer Casing Replacement: passo 3, imagem 2 %32
    • There are three parts of the sharpener.
    • Step 3: Grab the very top of the sharpener, twist it to the right and lift it up to remove it.
  4. Westcott iPoint Evolution Outer Casing Replacement: passo 4, imagem 1 %32 Westcott iPoint Evolution Outer Casing Replacement: passo 4, imagem 2 %32 Westcott iPoint Evolution Outer Casing Replacement: passo 4, imagem 3 %32
    • Step 4: Grab the center of the sharpener and lift it up to remove the piece.
  5. Westcott iPoint Evolution Outer Casing Replacement: passo 5, imagem 1 %32 Westcott iPoint Evolution Outer Casing Replacement: passo 5, imagem 2 %32 Westcott iPoint Evolution Outer Casing Replacement: passo 5, imagem 3 %32
    • Step 5: Remove the small ring that is around the sharpener.
    • This piece is below the center of the sharpener that you just removed.
  6. Westcott iPoint Evolution Outer Casing Replacement: passo 6, imagem 1 %32
    • Step 6: Flip the pencil sharpener upside down.
    • Locate the four screws on the bottom of the sharpener.
  7. Westcott iPoint Evolution Outer Casing Replacement: passo 7, imagem 1 %32
    • Step 7: Take a screwdriver and unscrew all of the screws on the bottom.
  8. Westcott iPoint Evolution Outer Casing Replacement: passo 8, imagem 1 %32
    • Step 8: After all the screws are removed gently take off the bottom of the sharpener.
  9. Westcott iPoint Evolution Outer Casing Replacement: passo 9, imagem 1 %32
    • Step 9: Carefully lift the lid off of the sharpener.
Conclusão
3 outras pessoas executaram este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 9
Últimos 30 dias: 35
Duração total: 11,829
