Ir para o conteúdo principal
Welch Allyn Connex Vital Signs Monitor 6000 Stand Replacement
O que você precisa
  1. Welch Allyn Connex Vital Signs Monitor 6000 Stand Replacement, Stand: passo 1, imagem 1 %32 Welch Allyn Connex Vital Signs Monitor 6000 Stand Replacement, Stand: passo 1, imagem 2 %32
    • Unplug the AC power connection cable.
  2. Welch Allyn Connex Vital Signs Monitor 6000 Stand Replacement: passo 2, imagem 1 %32 Welch Allyn Connex Vital Signs Monitor 6000 Stand Replacement: passo 2, imagem 2 %32 Welch Allyn Connex Vital Signs Monitor 6000 Stand Replacement: passo 2, imagem 3 %32
    • Place your thumb and forefinger on the blood pressure (NIBP) hose connector. Squeeze the side tabs until the connector releases.
    • Always grasp the hose by the connector. Do not pull on the hose itself.
    • Pull the connector away from the connector port.
  3. Welch Allyn Connex Vital Signs Monitor 6000 Stand Replacement: passo 3, imagem 1 %32 Welch Allyn Connex Vital Signs Monitor 6000 Stand Replacement: passo 3, imagem 2 %32 Welch Allyn Connex Vital Signs Monitor 6000 Stand Replacement: passo 3, imagem 3 %32
    • Place your thumb and forefinger on the Pulse oximetry (SpO2 or combined SpO2/SpHb) cable connector. Squeeze the side tabs until the connector releases.
    • Always grasp the cable by the connector. Do not pull on the cable itself.
  4. Welch Allyn Connex Vital Signs Monitor 6000 Stand Replacement: passo 4, imagem 1 %32 Welch Allyn Connex Vital Signs Monitor 6000 Stand Replacement: passo 4, imagem 2 %32
    • Grasp the temperature probe and pull it up to remove it from the monitor.
  5. Welch Allyn Connex Vital Signs Monitor 6000 Stand Replacement: passo 5, imagem 1 %32 Welch Allyn Connex Vital Signs Monitor 6000 Stand Replacement: passo 5, imagem 2 %32 Welch Allyn Connex Vital Signs Monitor 6000 Stand Replacement: passo 5, imagem 3 %32
    • Remove the cover of the temperature module by pressing the tab and sliding the cover to the right.
  6. Welch Allyn Connex Vital Signs Monitor 6000 Stand Replacement: passo 6, imagem 1 %32 Welch Allyn Connex Vital Signs Monitor 6000 Stand Replacement: passo 6, imagem 2 %32 Welch Allyn Connex Vital Signs Monitor 6000 Stand Replacement: passo 6, imagem 3 %32
    • Depress the spring tab on the temperature probe cable connector and withdraw it from the probe port.
  7. Welch Allyn Connex Vital Signs Monitor 6000 Stand Replacement: passo 7, imagem 1 %32
    • Remove the flathead screw on the USB networking door.
    • Loosen the captive Phillips #2 screw securing the monitor to the stand.
  8. Welch Allyn Connex Vital Signs Monitor 6000 Stand Replacement: passo 8, imagem 1 %32
    • Holding the monitor securely, open the USB networking door.
    • You may have to lift the monitor slightly to allow the door to swing out from the stand mount.
  9. Welch Allyn Connex Vital Signs Monitor 6000 Stand Replacement: passo 9, imagem 1 %32 Welch Allyn Connex Vital Signs Monitor 6000 Stand Replacement: passo 9, imagem 2 %32
    • Detach any accessory USB cables from USB ports on the monitor.
  10. Welch Allyn Connex Vital Signs Monitor 6000 Stand Replacement: passo 10, imagem 1 %32 Welch Allyn Connex Vital Signs Monitor 6000 Stand Replacement: passo 10, imagem 2 %32 Welch Allyn Connex Vital Signs Monitor 6000 Stand Replacement: passo 10, imagem 3 %32
    • Slide the monitor off of the stand tray.
Conclusão
Sam Goldheart
Membro desde: 10/18/12
465.762 Reputação
Autoria de 538 guias
Equipe
iFixit Membro de iFixit
Staff
Membros da 135
Autoria de 16.817 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 4
Duração total: 863
