Ir para o conteúdo principal
Welch Allyn Connex Vital Signs Monitor 6000 LCD Replacement
Equipamento Médico
Nem o iFixit nem este guia de reparo são endossados ou afiliados ao fabricante do dispositivo médico.
O que você precisa
  1. Welch Allyn Connex Vital Signs Monitor 6000 LCD Replacement, Stand: passo 1, imagem 1 %32 Welch Allyn Connex Vital Signs Monitor 6000 LCD Replacement, Stand: passo 1, imagem 2 %32
    • Unplug the AC power connection cable.
  2. Welch Allyn Connex Vital Signs Monitor 6000 LCD Replacement: passo 2, imagem 1 %32 Welch Allyn Connex Vital Signs Monitor 6000 LCD Replacement: passo 2, imagem 2 %32 Welch Allyn Connex Vital Signs Monitor 6000 LCD Replacement: passo 2, imagem 3 %32
    • Place your thumb and forefinger on the blood pressure (NIBP) hose connector. Squeeze the side tabs until the connector releases.
    • Always grasp the hose by the connector. Do not pull on the hose itself.
    • Pull the connector away from the connector port.
  3. Welch Allyn Connex Vital Signs Monitor 6000 LCD Replacement: passo 3, imagem 1 %32 Welch Allyn Connex Vital Signs Monitor 6000 LCD Replacement: passo 3, imagem 2 %32 Welch Allyn Connex Vital Signs Monitor 6000 LCD Replacement: passo 3, imagem 3 %32
    • Place your thumb and forefinger on the Pulse oximetry (SpO2 or combined SpO2/SpHb) cable connector. Squeeze the side tabs until the connector releases.
    • Always grasp the cable by the connector. Do not pull on the cable itself.
  4. Welch Allyn Connex Vital Signs Monitor 6000 LCD Replacement: passo 4, imagem 1 %32 Welch Allyn Connex Vital Signs Monitor 6000 LCD Replacement: passo 4, imagem 2 %32
    • Grasp the temperature probe and pull it up to remove it from the monitor.
  5. Welch Allyn Connex Vital Signs Monitor 6000 LCD Replacement: passo 5, imagem 1 %32 Welch Allyn Connex Vital Signs Monitor 6000 LCD Replacement: passo 5, imagem 2 %32 Welch Allyn Connex Vital Signs Monitor 6000 LCD Replacement: passo 5, imagem 3 %32
    • Remove the cover of the temperature module by pressing the tab and sliding the cover to the right.
  6. Welch Allyn Connex Vital Signs Monitor 6000 LCD Replacement: passo 6, imagem 1 %32 Welch Allyn Connex Vital Signs Monitor 6000 LCD Replacement: passo 6, imagem 2 %32 Welch Allyn Connex Vital Signs Monitor 6000 LCD Replacement: passo 6, imagem 3 %32
    • Depress the spring tab on the temperature probe cable connector and withdraw it from the probe port.
  7. Welch Allyn Connex Vital Signs Monitor 6000 LCD Replacement: passo 7, imagem 1 %32
    • Remove the flathead screw on the USB networking door.
    • Loosen the captive Phillips #2 screw securing the monitor to the stand.
  8. Welch Allyn Connex Vital Signs Monitor 6000 LCD Replacement: passo 8, imagem 1 %32
    • Holding the monitor securely, open the USB networking door.
    • You may have to lift the monitor slightly to allow the door to swing out from the stand mount.
  9. Welch Allyn Connex Vital Signs Monitor 6000 LCD Replacement: passo 9, imagem 1 %32 Welch Allyn Connex Vital Signs Monitor 6000 LCD Replacement: passo 9, imagem 2 %32
    • Detach any accessory USB cables from USB ports on the monitor.
  10. Welch Allyn Connex Vital Signs Monitor 6000 LCD Replacement: passo 10, imagem 1 %32 Welch Allyn Connex Vital Signs Monitor 6000 LCD Replacement: passo 10, imagem 2 %32 Welch Allyn Connex Vital Signs Monitor 6000 LCD Replacement: passo 10, imagem 3 %32
    • Slide the monitor off of the stand tray.
  11. Welch Allyn Connex Vital Signs Monitor 6000 LCD Replacement, Battery: passo 11, imagem 1 %32 Welch Allyn Connex Vital Signs Monitor 6000 LCD Replacement, Battery: passo 11, imagem 2 %32 Welch Allyn Connex Vital Signs Monitor 6000 LCD Replacement, Battery: passo 11, imagem 3 %32
    • Place the monitor upside down on a clean surface.
    • Insert a coin into the slot and push to open.
    • Choose a coin that fits comfortably into the slot.
    • Remove the battery cover.
  12. Welch Allyn Connex Vital Signs Monitor 6000 LCD Replacement: passo 12, imagem 1 %32 Welch Allyn Connex Vital Signs Monitor 6000 LCD Replacement: passo 12, imagem 2 %32 Welch Allyn Connex Vital Signs Monitor 6000 LCD Replacement: passo 12, imagem 3 %32
    • Use the plastic label to remove the battery from its recess.
  13. Welch Allyn Connex Vital Signs Monitor 6000 LCD Replacement, Rear Housing: passo 13, imagem 1 %32 Welch Allyn Connex Vital Signs Monitor 6000 LCD Replacement, Rear Housing: passo 13, imagem 2 %32
    • Open the communications door to access the lower left-hand rear housing screw.
    • Remove the four Phillips #2 screws (labeled 14 in the service manual) from the rear housing.
  14. Welch Allyn Connex Vital Signs Monitor 6000 LCD Replacement: passo 14, imagem 1 %32 Welch Allyn Connex Vital Signs Monitor 6000 LCD Replacement: passo 14, imagem 2 %32
    • With the handle/alert bar facing you, begin to lift the rear housing from the left side, holding the right side securely.
    • Do not attempt to separate the rear housing from the monitor, it is still attached with several cables.
  15. Welch Allyn Connex Vital Signs Monitor 6000 LCD Replacement: passo 15, imagem 1 %32
    • Support the rear housing while you disconnect the cables in the following steps.
  16. Welch Allyn Connex Vital Signs Monitor 6000 LCD Replacement: passo 16, imagem 1 %32 Welch Allyn Connex Vital Signs Monitor 6000 LCD Replacement: passo 16, imagem 2 %32 Welch Allyn Connex Vital Signs Monitor 6000 LCD Replacement: passo 16, imagem 3 %32
    • Disconnect the fan cable (labeled connector A in the service manual) from its socket in the power supply.
  17. Welch Allyn Connex Vital Signs Monitor 6000 LCD Replacement: passo 17, imagem 1 %32 Welch Allyn Connex Vital Signs Monitor 6000 LCD Replacement: passo 17, imagem 2 %32 Welch Allyn Connex Vital Signs Monitor 6000 LCD Replacement: passo 17, imagem 3 %32
    • Unplug the small USB connector from its socket (labeled J4 in the service manual).
  18. Welch Allyn Connex Vital Signs Monitor 6000 LCD Replacement: passo 18, imagem 1 %32 Welch Allyn Connex Vital Signs Monitor 6000 LCD Replacement: passo 18, imagem 2 %32 Welch Allyn Connex Vital Signs Monitor 6000 LCD Replacement: passo 18, imagem 3 %32
    • Disconnect the communications power cable from its socket (labeled J50 in the service manual).
    • Only pull on the connector itself and not the socket. This connection is very tight, work the connector slowly and gently.
  19. Welch Allyn Connex Vital Signs Monitor 6000 LCD Replacement: passo 19, imagem 1 %32 Welch Allyn Connex Vital Signs Monitor 6000 LCD Replacement: passo 19, imagem 2 %32 Welch Allyn Connex Vital Signs Monitor 6000 LCD Replacement: passo 19, imagem 3 %32
    • Unplug the large USB connector from its socket (labeled J8 in the service manual).
  20. Welch Allyn Connex Vital Signs Monitor 6000 LCD Replacement: passo 20, imagem 1 %32 Welch Allyn Connex Vital Signs Monitor 6000 LCD Replacement: passo 20, imagem 2 %32 Welch Allyn Connex Vital Signs Monitor 6000 LCD Replacement: passo 20, imagem 3 %32
    • Press the tab on the ethernet cable and unplug it from its socket (labeled J9 in the service manual).
  21. Welch Allyn Connex Vital Signs Monitor 6000 LCD Replacement: passo 21, imagem 1 %32
    • The following connector requires two hands to disconnect. Flip the rear case over, and lay it on its back to gain access to the power supply cable.
  22. Welch Allyn Connex Vital Signs Monitor 6000 LCD Replacement: passo 22, imagem 1 %32 Welch Allyn Connex Vital Signs Monitor 6000 LCD Replacement: passo 22, imagem 2 %32 Welch Allyn Connex Vital Signs Monitor 6000 LCD Replacement: passo 22, imagem 3 %32
    • The power supply cable is secured by an interlocking connector that must be held open to unplug the connector.
    • Insert the flat end of a spudger down into the power supply cover between the socket clip and the power supply connector.
  23. Welch Allyn Connex Vital Signs Monitor 6000 LCD Replacement: passo 23, imagem 1 %32 Welch Allyn Connex Vital Signs Monitor 6000 LCD Replacement: passo 23, imagem 2 %32 Welch Allyn Connex Vital Signs Monitor 6000 LCD Replacement: passo 23, imagem 3 %32
    • Grasp the power supply cable firmly and lift both it and the spudger from the channel in the power supply housing to unplug the connector.
  24. Welch Allyn Connex Vital Signs Monitor 6000 LCD Replacement, Motherboard: passo 24, imagem 1 %32 Welch Allyn Connex Vital Signs Monitor 6000 LCD Replacement, Motherboard: passo 24, imagem 2 %32 Welch Allyn Connex Vital Signs Monitor 6000 LCD Replacement, Motherboard: passo 24, imagem 3 %32
    • Remove all USB connectors from their ports on the motherboard.
    • Note the USB locations before removal for ease of reassembly. The locations of the USB as seen in the manual are shown in the third image. Your unit may differ depending on options.
  25. Welch Allyn Connex Vital Signs Monitor 6000 LCD Replacement: passo 25, imagem 1 %32 Welch Allyn Connex Vital Signs Monitor 6000 LCD Replacement: passo 25, imagem 2 %32
    • Fold the USB cable bundle out of the way.
    • When reassembling, position each cable to extend approximately 1.5 inches past the separator as shown.
  26. Welch Allyn Connex Vital Signs Monitor 6000 LCD Replacement: passo 26, imagem 1 %32 Welch Allyn Connex Vital Signs Monitor 6000 LCD Replacement: passo 26, imagem 2 %32 Welch Allyn Connex Vital Signs Monitor 6000 LCD Replacement: passo 26, imagem 3 %32
    • Use the flat end of a spudger to "walk" the LCD cable connector (labeled J19 in the service manual) out of its socket.
    • Press first on one side of the connector, then the other to push it free. Be sure to press the connector itself, not the socket on the motherboard.
    • Pull the cable straight out of its socket.
  27. Welch Allyn Connex Vital Signs Monitor 6000 LCD Replacement: passo 27, imagem 1 %32 Welch Allyn Connex Vital Signs Monitor 6000 LCD Replacement: passo 27, imagem 2 %32 Welch Allyn Connex Vital Signs Monitor 6000 LCD Replacement: passo 27, imagem 3 %32
    • Pinch the fan cable connector (labeled J45 in the service manual) and pull straight up to remove it from its socket.
    • Be sure to pull only on the connector itself, not the socket on the motherboard.
  28. Welch Allyn Connex Vital Signs Monitor 6000 LCD Replacement: passo 28, imagem 1 %32 Welch Allyn Connex Vital Signs Monitor 6000 LCD Replacement: passo 28, imagem 2 %32 Welch Allyn Connex Vital Signs Monitor 6000 LCD Replacement: passo 28, imagem 3 %32
    • Pull the light bar cable connector (labeled J46 in the service manual) straight up out of its socket.
  29. Welch Allyn Connex Vital Signs Monitor 6000 LCD Replacement: passo 29, imagem 1 %32 Welch Allyn Connex Vital Signs Monitor 6000 LCD Replacement: passo 29, imagem 2 %32 Welch Allyn Connex Vital Signs Monitor 6000 LCD Replacement: passo 29, imagem 3 %32
    • Remove the communications board cable connector from its socket (labeled J49 in the service manual).
    • If you have a printer unit in your model, remove the printer power cable at this time, it is labeled J17 in the service manual.
  30. Welch Allyn Connex Vital Signs Monitor 6000 LCD Replacement: passo 30, imagem 1 %32 Welch Allyn Connex Vital Signs Monitor 6000 LCD Replacement: passo 30, imagem 2 %32 Welch Allyn Connex Vital Signs Monitor 6000 LCD Replacement: passo 30, imagem 3 %32
    • Carefully remove the speaker cable connector (labeled J12 in the service manual) from the motherboard.
  31. Welch Allyn Connex Vital Signs Monitor 6000 LCD Replacement: passo 31, imagem 1 %32 Welch Allyn Connex Vital Signs Monitor 6000 LCD Replacement: passo 31, imagem 2 %32 Welch Allyn Connex Vital Signs Monitor 6000 LCD Replacement: passo 31, imagem 3 %32
    • Lift the ZIF collar securing the power button cable (labeled J6 in the service manual) with the flat end of a spudger to loosen its grip.
    • Pull the power button cable straight up from its socket.
  32. Welch Allyn Connex Vital Signs Monitor 6000 LCD Replacement: passo 32, imagem 1 %32 Welch Allyn Connex Vital Signs Monitor 6000 LCD Replacement: passo 32, imagem 2 %32 Welch Allyn Connex Vital Signs Monitor 6000 LCD Replacement: passo 32, imagem 3 %32
    • Remove the smart-battery cable connector from its socket (labeled J34 in the service manual).
  33. Welch Allyn Connex Vital Signs Monitor 6000 LCD Replacement: passo 33, imagem 1 %32 Welch Allyn Connex Vital Signs Monitor 6000 LCD Replacement: passo 33, imagem 2 %32 Welch Allyn Connex Vital Signs Monitor 6000 LCD Replacement: passo 33, imagem 3 %32
    • Pinch the battery power connector and lift straight up to unclip it from its socket on the motherboard (labeled J29 in the service manual).
  34. Welch Allyn Connex Vital Signs Monitor 6000 LCD Replacement: passo 34, imagem 1 %32 Welch Allyn Connex Vital Signs Monitor 6000 LCD Replacement: passo 34, imagem 2 %32
    • Use the flat end of a spudger to separate the battery supply cable connector bracket from the socket (labeled J30 in the service manual).
    • Pull the battery supply cable connector straight up from the board.
  35. Welch Allyn Connex Vital Signs Monitor 6000 LCD Replacement: passo 35, imagem 1 %32 Welch Allyn Connex Vital Signs Monitor 6000 LCD Replacement: passo 35, imagem 2 %32
    • Carefully pull the LCD flex cable straight up from its socket in the motherboard (labeled J48 in the service manual).
  36. Welch Allyn Connex Vital Signs Monitor 6000 LCD Replacement: passo 36, imagem 1 %32 Welch Allyn Connex Vital Signs Monitor 6000 LCD Replacement: passo 36, imagem 2 %32
    • Remove the eight Phillips #1 screws from the motherboard.
    • The screw securing the ethernet cable bracket has a washer between it and the bracket. Take care not to lose it.
  37. Welch Allyn Connex Vital Signs Monitor 6000 LCD Replacement: passo 37, imagem 1 %32 Welch Allyn Connex Vital Signs Monitor 6000 LCD Replacement: passo 37, imagem 2 %32 Welch Allyn Connex Vital Signs Monitor 6000 LCD Replacement: passo 37, imagem 3 %32
    • Lift the motherboard from the light-bar side and pull it toward the edge of the case to free the ethernet cable connector from under the case.
    • Lift the motherboard out of the case to gain access to the ethernet cable connector.
    • Do not attempt to remove the board entirely as it is still connected to the monitor.
  38. Welch Allyn Connex Vital Signs Monitor 6000 LCD Replacement: passo 38, imagem 1 %32 Welch Allyn Connex Vital Signs Monitor 6000 LCD Replacement: passo 38, imagem 2 %32
    • Remove the ethernet cable connector (labeled J11 in the service manual) from the mother board.
  39. Welch Allyn Connex Vital Signs Monitor 6000 LCD Replacement, LCD: passo 39, imagem 1 %32 Welch Allyn Connex Vital Signs Monitor 6000 LCD Replacement, LCD: passo 39, imagem 2 %32
    • Remove the two Phillips #2 side housing screws from the bottom housing.
    • There are holes above the screws into which you may insert a standard size screwdriver to unscrew them.
  40. Welch Allyn Connex Vital Signs Monitor 6000 LCD Replacement: passo 40, imagem 1 %32
    • Remove the single Phillips #2 screw from the bottom housing near the speaker grille.
  41. Welch Allyn Connex Vital Signs Monitor 6000 LCD Replacement: passo 41, imagem 1 %32 Welch Allyn Connex Vital Signs Monitor 6000 LCD Replacement: passo 41, imagem 2 %32
    • Remove the bottom housing.
  42. Welch Allyn Connex Vital Signs Monitor 6000 LCD Replacement: passo 42, imagem 1 %32 Welch Allyn Connex Vital Signs Monitor 6000 LCD Replacement: passo 42, imagem 2 %32
    • Remove the ethernet cable, or simply tuck it out of the way.
  43. Welch Allyn Connex Vital Signs Monitor 6000 LCD Replacement: passo 43, imagem 1 %32 Welch Allyn Connex Vital Signs Monitor 6000 LCD Replacement: passo 43, imagem 2 %32 Welch Allyn Connex Vital Signs Monitor 6000 LCD Replacement: passo 43, imagem 3 %32
    • Remove the light-bar cable from the LCD bracket and move it out of the way.
    • During reassembly, refer to the third image for tape and cable replacement.
  44. Welch Allyn Connex Vital Signs Monitor 6000 LCD Replacement: passo 44, imagem 1 %32 Welch Allyn Connex Vital Signs Monitor 6000 LCD Replacement: passo 44, imagem 2 %32 Welch Allyn Connex Vital Signs Monitor 6000 LCD Replacement: passo 44, imagem 3 %32
    • Remove any tape from the LCD cable connector.
    • For reassembly, refer to the third image for tape and cable replacement.
  45. Welch Allyn Connex Vital Signs Monitor 6000 LCD Replacement: passo 45, imagem 1 %32 Welch Allyn Connex Vital Signs Monitor 6000 LCD Replacement: passo 45, imagem 2 %32
    • Pull the LCD cable connector, firmly and evenly, straight out of its socket.
  46. Welch Allyn Connex Vital Signs Monitor 6000 LCD Replacement: passo 46, imagem 1 %32
    • Remove the four Phillips #2 screws from the LCD bracket.
  47. Welch Allyn Connex Vital Signs Monitor 6000 LCD Replacement: passo 47, imagem 1 %32 Welch Allyn Connex Vital Signs Monitor 6000 LCD Replacement: passo 47, imagem 2 %32
    • Remove the LCD bracket.
  48. Welch Allyn Connex Vital Signs Monitor 6000 LCD Replacement: passo 48, imagem 1 %32 Welch Allyn Connex Vital Signs Monitor 6000 LCD Replacement: passo 48, imagem 2 %32
    • Use the flat end of a spudger to lift the LCD out of the rubber gasket frame.
  49. Welch Allyn Connex Vital Signs Monitor 6000 LCD Replacement: passo 49, imagem 1 %32 Welch Allyn Connex Vital Signs Monitor 6000 LCD Replacement: passo 49, imagem 2 %32
    • Remove the LCD from the front housing.
Conclusão
Uma outra pessoa concluiu este guia.
Sam Goldheart
Membro desde: 10/18/12
465.777 Reputação
Autoria de 538 guias
Equipe
iFixit Membro de iFixit
Staff
Membros da 135
Autoria de 16.817 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 3
Duração total: 1,201
