Ir para o conteúdo principal
Welch Allyn Connex Vital Signs Monitor 6000 Battery Replacement
Equipamento Médico
Nem o iFixit nem este guia de reparo são endossados ou afiliados ao fabricante do dispositivo médico.
O que você precisa
  1. Welch Allyn Connex Vital Signs Monitor 6000 Battery Replacement, Stand: passo 1, imagem 1 %32 Welch Allyn Connex Vital Signs Monitor 6000 Battery Replacement, Stand: passo 1, imagem 2 %32
    • Unplug the AC power connection cable.
  2. Welch Allyn Connex Vital Signs Monitor 6000 Battery Replacement: passo 2, imagem 1 %32 Welch Allyn Connex Vital Signs Monitor 6000 Battery Replacement: passo 2, imagem 2 %32 Welch Allyn Connex Vital Signs Monitor 6000 Battery Replacement: passo 2, imagem 3 %32
    • Place your thumb and forefinger on the blood pressure (NIBP) hose connector. Squeeze the side tabs until the connector releases.
    • Always grasp the hose by the connector. Do not pull on the hose itself.
    • Pull the connector away from the connector port.
  3. Welch Allyn Connex Vital Signs Monitor 6000 Battery Replacement: passo 3, imagem 1 %32 Welch Allyn Connex Vital Signs Monitor 6000 Battery Replacement: passo 3, imagem 2 %32 Welch Allyn Connex Vital Signs Monitor 6000 Battery Replacement: passo 3, imagem 3 %32
    • Place your thumb and forefinger on the Pulse oximetry (SpO2 or combined SpO2/SpHb) cable connector. Squeeze the side tabs until the connector releases.
    • Always grasp the cable by the connector. Do not pull on the cable itself.
  4. Welch Allyn Connex Vital Signs Monitor 6000 Battery Replacement: passo 4, imagem 1 %32 Welch Allyn Connex Vital Signs Monitor 6000 Battery Replacement: passo 4, imagem 2 %32
    • Grasp the temperature probe and pull it up to remove it from the monitor.
  5. Welch Allyn Connex Vital Signs Monitor 6000 Battery Replacement: passo 5, imagem 1 %32 Welch Allyn Connex Vital Signs Monitor 6000 Battery Replacement: passo 5, imagem 2 %32 Welch Allyn Connex Vital Signs Monitor 6000 Battery Replacement: passo 5, imagem 3 %32
    • Remove the cover of the temperature module by pressing the tab and sliding the cover to the right.
  6. Welch Allyn Connex Vital Signs Monitor 6000 Battery Replacement: passo 6, imagem 1 %32 Welch Allyn Connex Vital Signs Monitor 6000 Battery Replacement: passo 6, imagem 2 %32 Welch Allyn Connex Vital Signs Monitor 6000 Battery Replacement: passo 6, imagem 3 %32
    • Depress the spring tab on the temperature probe cable connector and withdraw it from the probe port.
  7. Welch Allyn Connex Vital Signs Monitor 6000 Battery Replacement: passo 7, imagem 1 %32
    • Remove the flathead screw on the USB networking door.
    • Loosen the captive Phillips #2 screw securing the monitor to the stand.
  8. Welch Allyn Connex Vital Signs Monitor 6000 Battery Replacement: passo 8, imagem 1 %32
    • Holding the monitor securely, open the USB networking door.
    • You may have to lift the monitor slightly to allow the door to swing out from the stand mount.
  9. Welch Allyn Connex Vital Signs Monitor 6000 Battery Replacement: passo 9, imagem 1 %32 Welch Allyn Connex Vital Signs Monitor 6000 Battery Replacement: passo 9, imagem 2 %32
    • Detach any accessory USB cables from USB ports on the monitor.
  10. Welch Allyn Connex Vital Signs Monitor 6000 Battery Replacement: passo 10, imagem 1 %32 Welch Allyn Connex Vital Signs Monitor 6000 Battery Replacement: passo 10, imagem 2 %32 Welch Allyn Connex Vital Signs Monitor 6000 Battery Replacement: passo 10, imagem 3 %32
    • Slide the monitor off of the stand tray.
  11. Welch Allyn Connex Vital Signs Monitor 6000 Battery Replacement, Battery: passo 11, imagem 1 %32 Welch Allyn Connex Vital Signs Monitor 6000 Battery Replacement, Battery: passo 11, imagem 2 %32 Welch Allyn Connex Vital Signs Monitor 6000 Battery Replacement, Battery: passo 11, imagem 3 %32
    • Place the monitor upside down on a clean surface.
    • Insert a coin into the slot and push to open.
    • Choose a coin that fits comfortably into the slot.
    • Remove the battery cover.
  12. Welch Allyn Connex Vital Signs Monitor 6000 Battery Replacement: passo 12, imagem 1 %32 Welch Allyn Connex Vital Signs Monitor 6000 Battery Replacement: passo 12, imagem 2 %32 Welch Allyn Connex Vital Signs Monitor 6000 Battery Replacement: passo 12, imagem 3 %32
    • Use the plastic label to remove the battery from its recess.
Conclusão
4 outras pessoas executaram este guia.
kyle2
Membro desde: 06/03/10
101 Reputação
Autoria de 1 guia
Equipe
Team Freedom Membro de Team Freedom
Community
1 Membro
Autoria de 3 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 5
Últimos 30 dias: 30
Duração total: 2,734
