Ir para o conteúdo principal
Weinmann VENTImotion and VENTIlogic Fascia Film Replacement
Equipamento Médico
Nem o iFixit nem este guia de reparo são endossados ou afiliados ao fabricante do dispositivo médico.
O que você precisa
  1. Weinmann VENTImotion and VENTIlogic Fascia Film Replacement, Fascia Film: passo 1, imagem 1 %32
    • Open the device
    • 1.Place the device on a non-slip surface with the top facing downwards
    • 2.Remove the filter cassette from the top part of the housing.
    • 3.Undo and remove the 6 screws (34)
  2. Weinmann VENTImotion and VENTIlogic Fascia Film Replacement: passo 2, imagem 1 %32
    • Remove the mains supply unit
    • Disconnect the power board/mains supply unit connecting cable (45) from the power board.
    • Slightly lift mains supply unit (44) and disconnect the mains input connector from the mains supply unit (44).
    • Lift the mains supply unit out of the top part of the housing.
    • Disconnect the power board/mains supply unit connecting cable from the mains supply unit.
  3. Weinmann VENTImotion and VENTIlogic Fascia Film Replacement: passo 4, imagem 1 %32 Weinmann VENTImotion and VENTIlogic Fascia Film Replacement: passo 4, imagem 2 %32
    • Remove box and filter holder
    • Release the pressure-side hose (74) from the box.
    • Lift box (58) and filter holder (37) out of the top part of the housing together.
    • Disconnect the box and the filter holder from one another by undoing the intake-side hose (73) from both parts.
  4. Weinmann VENTImotion and VENTIlogic Fascia Film Replacement: passo 5, imagem 1 %32
  5. Weinmann VENTImotion and VENTIlogic Fascia Film Replacement: passo 6, imagem 1 %32
    • Peel the protective film off the inside of the new fascia film and affix fascia film (33) to this area of the housing.
    • Ensure that the ribbon cable is pushed cleanly through the opening in the housing without any kinks.
    • Carefully pull the outer protective film off the new fascia film using a fingernail.
  6. Weinmann VENTImotion and VENTIlogic Fascia Film Replacement: passo 9, imagem 1 %32 Weinmann VENTImotion and VENTIlogic Fascia Film Replacement: passo 9, imagem 2 %32
    • Refit the box and filter holder.
    • Connect the box and the filter holder to one another by reconnecting the intake side hose (73) from both parts.
    • Refit box (58) and filter holder (37) back on the top part of the housing together.
    • Connect the pressure-side hose (74) from the box.
  7. Weinmann VENTImotion and VENTIlogic Fascia Film Replacement: passo 11, imagem 1 %32
    • Refit the mains supply unit
    • Reconnect the power board/mains supply unit connecting cable from the mains supply unit.
    • Put the mains supply unit back in the top part of the housing.
    • Reconnect the mains input connector from the mains supply unit (44).
    • Reconnect the power board/mains supply unit connecting cable (45) from the power board.
  8. Weinmann VENTImotion and VENTIlogic Fascia Film Replacement: passo 12, imagem 1 %32 Weinmann VENTImotion and VENTIlogic Fascia Film Replacement: passo 12, imagem 2 %32
    • Close the device
    • Hold the bottom part of the housing (35) up to the side of the top part of the housing (36)
    • Plug the connecting cables for the humidifier (42) and the alarm (43) onto the relevant connectors.
    • Check that all hoses and cables are plugged on firmly.
    • Place the bottom part of the housing (35) on the top part of the housing (36). Ensure that no cables or hoses are trapped or bent.
    • Now screw the top part of the housing tight using the 6 screws (34).
    • Then turn the device back over
Conclusão
Jay Vidinoff
Membro desde: 04/07/20
610 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team S7-G19, Paton Spring 2020 Membro de Cal Poly, Team S7-G19, Paton Spring 2020
CPSU-PATON-S20S7G19
Membros da 3
Autoria de 4 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 10
Duração total: 121
