Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Introdução
This guide will show you how you can waterproof your iPod Shuffle and earphones DIY, you will be able to use them in the pool in the bath or wherever water is.
O que você precisa
To start you need the items as pictured. To the right is the waterproof dipping liquid bottle from Nanostate called Flash Flood Green Label, it's 3ml.
4 comentários
Nanostate appears to be a scam. I've tried to order this twice, under different names and to different addresses. Both times, the product never shipped, and a refund was issued only after repeated requests for information from the company. Don't waste your time.
Shawn you purchased and said you never got the product, got refunded and then you ordered again in your wife's name and the order was cancelled as that looked like a fraudulent transaction and due to the same uncommon surnames. Why would you reorder again in a different name ?
Order Date : 2013-08-22
Shawn Perdue
Order Date : 2013-11-08
Christin Perdue
A scam is when someone takes your money or the product does not work, neither has happened to you.
The new website has been updated to http://www.nanostateco.com
is this product still available? I have tried the website but it doesn’t load
