Ir para o conteúdo principal
Water damage
  1. Water damage, Disassemble the primary frame: passo 1, imagem 1 %32 Water damage, Disassemble the primary frame: passo 1, imagem 2 %32
    • Use a piece of plastic, like a credit or store card, to open up the case.
  2. Water damage, Detach the secondary frame: passo 2, imagem 1 %32 Water damage, Detach the secondary frame: passo 2, imagem 2 %32 Water damage, Detach the secondary frame: passo 2, imagem 3 %32
    • Lift the cover with a plastic card and carefully pull it off.
    • Tip: The glue is very strong, so I recommend helping things along with the plastic card.
    • If you remove the cover slowly and don't stick the plastic card in too far, you might be able to re-use the strip of glue.
  3. Water damage, Detach display and mainboard: passo 3, imagem 1 %32 Water damage, Detach display and mainboard: passo 3, imagem 2 %32
    • Loosen the seven 20mm T5 screws.
    • Then slide the display upwards.
  4. Water damage, Disconnect the battery: passo 4, imagem 1 %32
    • Now the battery can be disconnected and replaced, if necessary.
  5. Water damage, Detach the display cable: passo 5, imagem 1 %32
    • This Kindle has water damage which corroded the display cable.
    • I think changing the display is not possible because it is glued to the mainboard, possibly even soldered. I won't try replacing it because I only need to clean the display connector.
Conclusão
Um agradecimento especial a esses tradutores:
de en
100%
Estes tradutores estão nos ajudando a consertar o mundo! Quer contribuir?
Comece a traduzir ›
Lukas Wolf
Membro desde: 02/17/24
121 Reputação
Autoria de 1 guia
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 40
Ao todo: 704
