Ir para o conteúdo principal
Water Filtration System Filter Replacement
O que você precisa
  1. Water Filtration System Filter Replacement, Filter: passo 1, imagem 1 %32 Water Filtration System Filter Replacement, Filter: passo 1, imagem 2 %32
    • Turn off water supply.
  2. Water Filtration System Filter Replacement: passo 2, imagem 1 %32
    • Press the button on the top of the filtration device to release water pressure and let excess water drain.
  3. Water Filtration System Filter Replacement: passo 3, imagem 1 %32 Water Filtration System Filter Replacement: passo 3, imagem 2 %32
    • Unscrew the filter canister using the canister wrench.
  4. Water Filtration System Filter Replacement: passo 4, imagem 1 %32 Water Filtration System Filter Replacement: passo 4, imagem 2 %32
    • Take out the old filter and discard it.
  5. Water Filtration System Filter Replacement: passo 5, imagem 1 %32
    • Clean out the inside of the filter canister with soap and water.
  6. Water Filtration System Filter Replacement: passo 6, imagem 1 %32
    • Put the new filter inside the filter canister, making sure it goes in properly.
  7. Water Filtration System Filter Replacement: passo 7, imagem 1 %32 Water Filtration System Filter Replacement: passo 7, imagem 2 %32 Water Filtration System Filter Replacement: passo 7, imagem 3 %32
    • Screw the filter canister back into place using the canister wrench, making sure it's tightly screwed in.
  8. Water Filtration System Filter Replacement: passo 8, imagem 1 %32 Water Filtration System Filter Replacement: passo 8, imagem 2 %32
    • Turn the water supply back on.
  9. Water Filtration System Filter Replacement: passo 9, imagem 1 %32
    • Press the button on the top of the device to release any air trapped inside.
Conclusão
You have now successfully replaced your water filter.
Tahj Ramirez
Membro desde: 07/08/20
223 Reputação
Autoria de 1 guia
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 6
Últimos 7 dias: 31
Últimos 30 dias: 123
Duração total: 1,828
