Ir para o conteúdo principal
Water Damage on main board of Nokia 206 RM873
O que você precisa
  1. Water Damage on main board of Nokia 206 RM873, Water Damage on main board of Nokia 206 RM873: passo 1, imagem 1 %32 Water Damage on main board of Nokia 206 RM873, Water Damage on main board of Nokia 206 RM873: passo 1, imagem 2 %32 Water Damage on main board of Nokia 206 RM873, Water Damage on main board of Nokia 206 RM873: passo 1, imagem 3 %32
    • Remove back cover & battery.
  2. Water Damage on main board of Nokia 206 RM873: passo 2, imagem 1 %32 Water Damage on main board of Nokia 206 RM873: passo 2, imagem 2 %32
    • Remove the front case by prying it open. You will hear clicks.
    • Be careful with taking off screen if you use a spudger.
  3. Water Damage on main board of Nokia 206 RM873: passo 3, imagem 1 %32 Water Damage on main board of Nokia 206 RM873: passo 3, imagem 2 %32
    • Use a Torx screwdriver to remove the screen screws.
    • Use a spudger or tweezers to remove the connector of the LCD screen.
  4. Water Damage on main board of Nokia 206 RM873: passo 4, imagem 1 %32 Water Damage on main board of Nokia 206 RM873: passo 4, imagem 2 %32 Water Damage on main board of Nokia 206 RM873: passo 4, imagem 3 %32
    • The PCB board had water damage, see this in picture 3.
    • To remove the corrosion, dab a cotton swab with a little distilled water on the corroded area, the corrosion will disappear.
  5. Water Damage on main board of Nokia 206 RM873: passo 5, imagem 1 %32 Water Damage on main board of Nokia 206 RM873: passo 5, imagem 2 %32
    • How and where to use the cotton swabs.
Conclusão
17 outras pessoas executaram este guia.
Kevin D
Membro desde: 05/02/14
7.294 Reputação
Autoria de 21 guias
4 comentários
no use .it is not switching on . replaced with good batter also. no on
nabhan75 - Responder
try to clean with an ultrasonic bath.
measure out powerrail.
measure out the voltage coming in on board. try to see if you have short.
Kevin D - Responder
Nokia 206 display and charger pin
Mithilesh Yadav - Responder
Not working kiy 1.2.3 and colling ricev kiy not working
K .M Jugesh - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 14
Últimos 30 dias: 37
Duração total: 10,779
