Ir para o conteúdo principal
Watch Strap Buckle Replacement
O que você precisa
  1. Watch Strap Buckle Replacement, Leather Watch Strap Buckle: passo 1, imagem 1 %32
    • Hold the spring bar tool in your dominant hand and the watch strap with your non dominant hand.
    • Locate the pointed end of the spring bar.
  2. Watch Strap Buckle Replacement: passo 2, imagem 1 %32
    • Insert the pointed end of the spring bar tool into the hole on the side of the buckle.
    • Press down on the spring bar and gently push it to the side until the end of the spring bar comes out from under the metal buckle.
  3. Watch Strap Buckle Replacement: passo 3, imagem 1 %32 Watch Strap Buckle Replacement: passo 3, imagem 2 %32 Watch Strap Buckle Replacement: passo 3, imagem 3 %32
    • Remove the U-shaped part of the buckle.
    • The spring bar may shoot out.
  4. Watch Strap Buckle Replacement: passo 4, imagem 1 %32 Watch Strap Buckle Replacement: passo 4, imagem 2 %32 Watch Strap Buckle Replacement: passo 4, imagem 3 %32
    • Remove the spring bar and metal tongue.
  5. Watch Strap Buckle Replacement: passo 5, imagem 1 %32
    • Insert the new spring bar half way.
    • Do not cover the center of the buckle. This will prevent the completion of the next step.
  6. Watch Strap Buckle Replacement: passo 6, imagem 1 %32
    • Insert the new tongue, positioning the end facing down in relation to the watch strap.
    • Hold the tongue in place and slide the spring bar through the end of the strap.
    • You should be able to see both ends of the spring bar.
  7. Watch Strap Buckle Replacement: passo 7, imagem 1 %32 Watch Strap Buckle Replacement: passo 7, imagem 2 %32
    • Holding the spring bar in place, take the U-shaped part of the new buckle and line it up with the ends of the strap.
  8. Watch Strap Buckle Replacement: passo 8, imagem 1 %32 Watch Strap Buckle Replacement: passo 8, imagem 2 %32
    • Insert one end of the spring bar into the U-shaped piece of the buckle.
    • Use the forked end of the spring bar tool to push the spring bar down so you can slide the metal buckle over it.
    • This will lock in the buckle on each end of the spring bar.
  9. Watch Strap Buckle Replacement: passo 9, imagem 1 %32
    • When the buckle covers the spring bar, gently remove the spring bar tool until you hear the spring bar snap into place.
    • If you do not hear a snap, move the buckle gently until you hear a snap.
  10. Watch Strap Buckle Replacement: passo 10, imagem 1 %32
    • Give the buckle a few gentle tugs to make sure that it remains in place.
    • If it does, then you are finished and ready to wear your watch. If the buckle falls off, repeat steps 6-11.
Linha de Chegada
Daisha Paringit
Membro desde: 04/28/17
117 Reputação
Autoria de 1 guia
Equipe
UC Davis, Team S4-G5, Cole Spring 2017 Membro de UC Davis, Team S4-G5, Cole Spring 2017
UCD-COLE-S17S4G5
Membros da 4
1 Guia de autoria
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 11
Últimos 30 dias: 36
Duração total: 6,136
