Ir para o conteúdo principal
Watch Battery Replacement
O que você precisa
  1. Watch  Battery Replacement, Battery: passo 1, imagem 1 %32 Watch  Battery Replacement, Battery: passo 1, imagem 2 %32
    • Place your watch in the watch holder, and adjust the sizing screw to the appropriate size for your watch.
    • If you do not have a holder, you can hold the watch yourself and still be able to complete the repair.
    Pergunte ao FixBot
    Comentar
  2. Watch  Battery Replacement: passo 2, imagem 1 %32
    • Next, you will have to adjust the dimensions of the watch back remover tool you will use to take the watch back off. The dimensions should be set so the tool properly fits the three connection points on the back of the watch. You can do this by screwing or unscrewing the adjustment screws on the tool.
    Pergunte ao FixBot
    Comentar
  3. Watch  Battery Replacement: passo 3, imagem 1 %32
    • Turn the tool counterclockwise until the back of the watch is completely off.
    • You will need to hold the watch band up while you complete this step.
    Pergunte ao FixBot
    Comentar
  4. Watch  Battery Replacement: passo 4, imagem 1 %32 Watch  Battery Replacement: passo 4, imagem 2 %32
    Ferramenta utilizada neste passo:
    • Use tweezers to carefully remove the current watch battery. Next, place the new battery in the same spot and orientation you removed the previous battery from.
    • Do not touch or remove any other piece inside of the watch.
    Pergunte ao FixBot
    Comentar
  5. Watch  Battery Replacement: passo 5, imagem 1 %32
    • Place the back of the watch back on and align the watch back remover tool to the three connection points. Then, turn the tool clockwise until the back of the watch is tightly secured.
    Pergunte ao FixBot
    Comentar
  6. Watch  Battery Replacement: passo 6, imagem 1 %32
    • Check the watch for proper operation and set it to the correct time.
    Pergunte ao FixBot
    Comentar
Conclusão
5 outras pessoas executaram este guia.
Maria Pina
Membro desde: 09/11/15
217 Reputação
Autoria de 1 guia
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 20
Últimos 30 dias: 107
Ao todo: 3,006
