Ir para o conteúdo principal
Waring 51BL29 Switch Replacement
O que você precisa
  1. Waring 51BL29 Switch Replacement, Bottom Panel: passo 1, imagem 1 %32 Waring 51BL29 Switch Replacement, Bottom Panel: passo 1, imagem 2 %32
    • Turn the blender on its side so the bottom panel is facing you.
    • Unscrew the 22mm Phillips #1 screw on the indent of the panel.
    • Unscrew the 3 screws in the rubber holes.
  2. Waring 51BL29 Switch Replacement: passo 2, imagem 1 %32
    • Remove the bottom panel.
  3. Waring 51BL29 Switch Replacement, Drive Coupling: passo 3, imagem 1 %32
    • Place the screwdriver in the head of the middle flat-head screw.
  4. Waring 51BL29 Switch Replacement: passo 4, imagem 1 %32
    • Unscrew this screw while holding the coupling with your other hand and not allowing it to rotate.
    • This screw may be reverse-threaded.
  5. Waring 51BL29 Switch Replacement: passo 5, imagem 1 %32
    • Once the coupling mechanism has been loosened all the way, gently pull it off the top of the blender.
  6. Waring 51BL29 Switch Replacement, Motor: passo 6, imagem 1 %32 Waring 51BL29 Switch Replacement, Motor: passo 6, imagem 2 %32
    • Unscrew the four nuts in the bottom of the motor cavity.
    • Wiggle the motor until it is free and you can remove it.
  7. Waring 51BL29 Switch Replacement: passo 7, imagem 1 %32
    • Once motor is pulled out, unscrew the 8 mm screw for the green wire from the base of the blender.
  8. Waring 51BL29 Switch Replacement: passo 8, imagem 1 %32 Waring 51BL29 Switch Replacement: passo 8, imagem 2 %32 Waring 51BL29 Switch Replacement: passo 8, imagem 3 %32
    • Unscrew each white wire cap in order to free the motor from the power cord.
    • Once wire caps are removed, separate wires carefully.
  9. Waring 51BL29 Switch Replacement, Switch: passo 9, imagem 1 %32
    • Once you have the motor and switch by themselves it should look like this.
  10. Waring 51BL29 Switch Replacement: passo 10, imagem 1 %32 Waring 51BL29 Switch Replacement: passo 10, imagem 2 %32
    • Separate the zip-tie holding the wires to the motor.
  11. Waring 51BL29 Switch Replacement: passo 11, imagem 1 %32
    • Now the switch is separated from the motor and blender frame.
Conclusão
Dean Becker
Membro desde: 04/17/17
470 Reputação
Autoria de 4 guias
Equipe
Cal Poly, Team S15-G4, Banghart Spring 2017 Membro de Cal Poly, Team S15-G4, Banghart Spring 2017
CPSU-BANGHART-S17S15G4
Membros da 4
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 12
Duração total: 682
