Ir para o conteúdo principal
Waring 51BL29 Drive Coupling Replacement
O que você precisa
  1. Waring 51BL29 Drive Coupling Replacement, Bottom Panel: passo 1, imagem 1 %32 Waring 51BL29 Drive Coupling Replacement, Bottom Panel: passo 1, imagem 2 %32
    • Turn the blender on its side so the bottom panel is facing you.
    • Unscrew the 22mm Phillips #1 screw on the indent of the panel.
    • Unscrew the 3 screws in the rubber holes.
  2. Waring 51BL29 Drive Coupling Replacement: passo 2, imagem 1 %32
    • Remove the bottom panel.
  3. Waring 51BL29 Drive Coupling Replacement, Drive Coupling: passo 3, imagem 1 %32
    • Place the screwdriver in the head of the middle flat-head screw.
  4. Waring 51BL29 Drive Coupling Replacement: passo 4, imagem 1 %32
    • Unscrew this screw while holding the coupling with your other hand and not allowing it to rotate.
    • This screw may be reverse-threaded.
  5. Waring 51BL29 Drive Coupling Replacement: passo 5, imagem 1 %32
    • Once the coupling mechanism has been loosened all the way, gently pull it off the top of the blender.
Conclusão
4 outras pessoas executaram este guia.
Dean Becker
Membro desde: 04/17/17
470 Reputação
Autoria de 4 guias
Equipe
Cal Poly, Team S15-G4, Banghart Spring 2017 Membro de Cal Poly, Team S15-G4, Banghart Spring 2017
CPSU-BANGHART-S17S15G4
Membros da 4
Autoria de 5 guias
Um comentário
Do you happen to know where I can purchase this replacement part?
Jessica Dye - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 18
Últimos 30 dias: 43
Duração total: 4,292
