Ir para o conteúdo principal
Wall Outlet Cover Replacement
O que você precisa
  1. Wall Outlet Cover Replacement, Wall Outlet Cover: passo 1, imagem 1 %32 Wall Outlet Cover Replacement, Wall Outlet Cover: passo 1, imagem 2 %32 Wall Outlet Cover Replacement, Wall Outlet Cover: passo 1, imagem 3 %32
    • Remove any hazardous pieces from previous cover.
    • Be sure to remove the two flathead screws to remove any debris, rather than trying to pull off the sharp pieces.
  2. Wall Outlet Cover Replacement: passo 2, imagem 1 %32 Wall Outlet Cover Replacement: passo 2, imagem 2 %32 Wall Outlet Cover Replacement: passo 2, imagem 3 %32
    • Insert any cable or cables that may be hanging out inside of the wall hole.
    • Making a loop in the cable might be helpful to push it inside the wall.
  3. Wall Outlet Cover Replacement: passo 3, imagem 1 %32
    • Insert two screws into the holes of the new wall cover.
  4. Wall Outlet Cover Replacement: passo 4, imagem 1 %32 Wall Outlet Cover Replacement: passo 4, imagem 2 %32 Wall Outlet Cover Replacement: passo 4, imagem 3 %32
    • Line up the screws in the plate with the screw holes in the wall.
    • Tighten the screws slightly with your hands to ensure that both screws have found the proper holes.
    • Once the screws have been tightened enough to stay in the holes, they should hold the outlet cover in place.
  5. Wall Outlet Cover Replacement: passo 5, imagem 1 %32 Wall Outlet Cover Replacement: passo 5, imagem 2 %32 Wall Outlet Cover Replacement: passo 5, imagem 3 %32
    • Tighten the two screws with a flathead screwdriver.
  6. Wall Outlet Cover Replacement: passo 6, imagem 1 %32 Wall Outlet Cover Replacement: passo 6, imagem 2 %32 Wall Outlet Cover Replacement: passo 6, imagem 3 %32
    • Double check that the wall cover plate does not have a gap, and it is completely attached to the wall.
    • If any gap is detected, push the plate to the wall and continue to tighten the screws until the gap completely closes.
Conclusão
Leydi Navarrete
Membro desde: 04/12/21
133 Reputação
Autoria de 1 guia
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 15
Últimos 30 dias: 55
Duração total: 1,078
