Ir para o conteúdo principal
Wahl Professional Designer Power Switch Replacement
O que você precisa
  1. Wahl Professional Designer Power Switch Replacement, Power Switch: passo 1, imagem 1 %32 Wahl Professional Designer Power Switch Replacement, Power Switch: passo 1, imagem 2 %32
    • Unscrew the 12 mm Phillips head screws located at the top of the cover and at the bottom two corners, using a Phillips #1 Screwdriver.
  2. Wahl Professional Designer Power Switch Replacement: passo 2, imagem 1 %32 Wahl Professional Designer Power Switch Replacement: passo 2, imagem 2 %32
    • Unscrew the two black 5.556 mm Phillip head screw on the power switch with a Phillips #0 Screwdriver.
  3. Wahl Professional Designer Power Switch Replacement: passo 3, imagem 1 %32 Wahl Professional Designer Power Switch Replacement: passo 3, imagem 2 %32 Wahl Professional Designer Power Switch Replacement: passo 3, imagem 3 %32
    • Shimmy the power switch off the mount until it is completely removed.
Conclusão
Sophia Swearengin
Membro desde: 09/26/17
718 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team S14-G5, Boczar Fall 2017 Membro de USF Tampa, Team S14-G5, Boczar Fall 2017
USFT-BOCZAR-F17S14G5
Membros da 2
Autoria de 5 guias
Um comentário
Hello Mrs/ms Swearengin, I’m disassembled my Wahl desingner I’m unable to make the power switch stiff . It’s very loose I can’t recall which screw goes in between two black 5.556 mm Phillip head screw or if it needs a screw at all
Carlos Olvera - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 554
