Introdução
If your device is not working due to a problem with your power cord this guide will allow you to replace it to fix your problem.
O que você precisa
Unscrew the 12 mm Phillips head screws located at the top of the cover and at the bottom two corners, using a Phillips #1 Screwdriver.
Quase terminado!
Conclusão
