Ir para o conteúdo principal
Wahl Lithium Ion 5537C Blade Replacement
O que você precisa
  1. Wahl Lithium Ion 5537C Blade Replacement, Shaver Blade: passo 1, imagem 1 %32 Wahl Lithium Ion 5537C Blade Replacement, Shaver Blade: passo 1, imagem 2 %32
    • Take out the batteries by pulling off the cover from the back and once done put the cover back on.
  2. Wahl Lithium Ion 5537C Blade Replacement: passo 2, imagem 1 %32 Wahl Lithium Ion 5537C Blade Replacement: passo 2, imagem 2 %32 Wahl Lithium Ion 5537C Blade Replacement: passo 2, imagem 3 %32
    • Using the Phillips #0 screwdriver, remove the two screws on the blade and place them in the container.
    • Detach the blade from the body of the shaver and also remove the blade supporting mounts.
  3. Wahl Lithium Ion 5537C Blade Replacement: passo 3, imagem 1 %32 Wahl Lithium Ion 5537C Blade Replacement: passo 3, imagem 2 %32 Wahl Lithium Ion 5537C Blade Replacement: passo 3, imagem 3 %32
    • Grab the replacement new blade and before mounting the support mount clean it with the cleaning brush to remove any dirt.
    • Place the supporting mount back to the new blade making sure it is properly attached.
  4. Wahl Lithium Ion 5537C Blade Replacement: passo 4, imagem 1 %32 Wahl Lithium Ion 5537C Blade Replacement: passo 4, imagem 2 %32 Wahl Lithium Ion 5537C Blade Replacement: passo 4, imagem 3 %32
    • Place the blade with mount attached to the trimmer such that the screw holes are visible through
    • Grab on the blade hard and torque both screws one by one.
    • Check if the blade is attached tightly to the trimmer.
    • Insert the batteries inside the trimmer and start using!
Conclusão
Uma outra pessoa concluiu este guia.
Osman Saeed
Membro desde: 07/11/21
109 Reputação
Autoria de 1 guia
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 2
Últimos 30 dias: 32
Duração total: 1,159
