Ir para o conteúdo principal
Wahl Hair Clippers Model ST115VAC Power Cord Replacement
O que você precisa
  1. Wahl Hair Clippers  Model ST115VAC Power Cord  Replacement, Power Cord: passo 1, imagem 1 %32
    • Unscrew the three 12mm black JIS screw found on the red side of the the device with a JIS #1 driver.
  2. Wahl Hair Clippers  Model ST115VAC Power Cord  Replacement: passo 2, imagem 1 %32
    • Grab the red cover by the side and lift off the top piece.
  3. Wahl Hair Clippers  Model ST115VAC Power Cord  Replacement: passo 3, imagem 1 %32
    • Unscrew the 5.556mm screw with a JIS #0 screwdriver. (Black Screw located at power switch)
  4. Wahl Hair Clippers  Model ST115VAC Power Cord  Replacement: passo 4, imagem 1 %32
    Ferramenta utilizada nesse passo:
    Spudger
    $2.99
    Comprar
    • Insert the metal spudger between the wire connector and the device connector. The spudger should disengage a tension-like lock between both connectors, and once disengaged gently pry out the cord connection.
    • (Note-dependent on varying user conditions, the connection may be harder to remove and may involve more force or a gentle rocking to separate connection.)
    • When working with electronics, make to use an ESD safe tool, to avoid shock. Try using the black nylon spudger instead.
  5. Wahl Hair Clippers  Model ST115VAC Power Cord  Replacement: passo 5, imagem 1 %32
    • Remove the cord from the fixed position.
Conclusão
To reassemble your device, follow these instructions in reverse order. When installing new cord, make sure black wire is underneath the white wire.
3 outras pessoas executaram este guia.
Julio Alvarado
Membro desde: 02/15/17
131 Reputação
Autoria de 1 guia
Equipe
USF Tampa, Team 10-4, Remmell Spring 2017 Membro de USF Tampa, Team 10-4, Remmell Spring 2017
USFT-REMMELL-S17S10G4
Membros da 4
1 Guia de autoria
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 7
Últimos 30 dias: 29
Duração total: 2,945
