Ir para o conteúdo principal
Wahl Chrome Pro Motor Replacement
O que você precisa
  1. Wahl Chrome Pro Motor Replacement, Case: passo 1, imagem 1 %32
    • Remove the two 5.0 mm JIS #1 screws to loosen the cutting blades.
    • Make sure your device is not connected to power before you begin.
  2. Wahl Chrome Pro Motor Replacement: passo 2, imagem 1 %32
    • Lift the bottom blade straight up from the device body to remove it.
  3. Wahl Chrome Pro Motor Replacement: passo 3, imagem 1 %32
    • Remove the three 9.0 mm JIS #1 screws attaching the base of the blade assembly to the body.
  4. Wahl Chrome Pro Motor Replacement: passo 4, imagem 1 %32
    • Lift the base of blade assembly straight up off of the body.
  5. Wahl Chrome Pro Motor Replacement: passo 5, imagem 1 %32
    • Remove the two 12.0 mm JIS #1 screws on the back of the device body.
  6. Wahl Chrome Pro Motor Replacement: passo 6, imagem 1 %32
    • Remove the 13.0 mm Phillips #2 screw on the side of the device body.
    • This screw is located on the opposite side of the body from the switch.
  7. Wahl Chrome Pro Motor Replacement: passo 7, imagem 1 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Remove the spring on the side of the body using tweezers.
  8. Wahl Chrome Pro Motor Replacement: passo 8, imagem 1 %32
    • Pry the body case off of the device using a spudger.
  9. Wahl Chrome Pro Motor Replacement, Motor: passo 9, imagem 1 %32
    • Lift power cord tab (black wire) from slot on motor base.
  10. Wahl Chrome Pro Motor Replacement: passo 10, imagem 1 %32
    • Lift switch tab (teal wire) from slot on motor base.
  11. Wahl Chrome Pro Motor Replacement: passo 11, imagem 1 %32
    • Remove two 23.0 mm JIS #1 screws attaching motor base to device body.
  12. Wahl Chrome Pro Motor Replacement: passo 12, imagem 1 %32
    • Lift motor base straight up from device body to remove.
Conclusão
Ashley Dale
Membro desde: 11/09/17
285 Reputação
Autoria de 2 guias
Equipe
IUPUI, Team S7-G3, Baechle Fall 2017 Membro de IUPUI, Team S7-G3, Baechle Fall 2017
IUPUI-BAECHLE-F17S7G3
Membros da 3
Autoria de 4 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 17
Duração total: 1,246
