Ir para o conteúdo principal
Wacom Intuos4 Foam Safety Pad Replacement
O que você precisa
  1. Wacom Intuos4 Foam Safety Pad Replacement, Casing: passo 1, imagem 1 %32 Wacom Intuos4 Foam Safety Pad Replacement, Casing: passo 1, imagem 2 %32 Wacom Intuos4 Foam Safety Pad Replacement, Casing: passo 1, imagem 3 %32
    • Flip device on its back and remove all fourteen 7.1 mm screws using a Phillips #1 screwdriver.
    • There is a single screw located under each of the rubber leg pieces. Use a shimmy tool to remove these pieces to access the screws.
  2. Wacom Intuos4 Foam Safety Pad Replacement: passo 2, imagem 1 %32 Wacom Intuos4 Foam Safety Pad Replacement: passo 2, imagem 2 %32
    • Lift the screen's foam backing connecting the motherboard/drawing board to the two smaller express-key boards, placing it onto the motherboard.
    • Separate the outer casing from the rest of the tablet.
  3. Wacom Intuos4 Foam Safety Pad Replacement, Foam Safety Pad: passo 3, imagem 1 %32
    • Use a spudger to safely remove the white and sliver pad without applying enough pressure to scratch the motherboard.
Conclusão
Aidan Sullivan
Membro desde: 10/26/22
293 Reputação
Autoria de 2 guias
Equipe
UMass Dartmouth, Team 3-6, Botvin Fall 2022 Membro de UMass Dartmouth, Team 3-6, Botvin Fall 2022
UMASSD-BOTVIN-F22S3G6
Membros da 4
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 13
Duração total: 138
