Introdução
Welcome!
If your plate compactor isn’t vibrating but the engine is running fine, a great place to start is by inspecting the V-belt and replacing it if damaged. It is also good practice to inspect the V-belt regularly and to keep the V-belt housing clean in order to reduce wear and prevent the tool from failing when it is needed.
O que você precisa
The V-belt is located in a large gray compartment on the left side of the machine
There are two 1/2 in bolts in the center of the belt guard cover that hold it on. Loosen them using the 1/2 in socket and the 3/8 in drive ratchet, but don't fully remove them
Remove the belt guard cover and set it aside
Rotate the belt slowly, inspecting for signs of damage such as the crack shown
Pull part of the V-belt up and over the top of the large pulley with one hand
Maintain tension on the belt while using your other hand to rotate the pulley clockwise until the belt comes off. This will require a bit of force
Clean any dirt or residue off of the area where the belt rode on the pulleys to ensure the new belt doesn't get any unnecessary wear
Loop the bottom of the belt around the small pulley
Pull the top of the belt around the bottom of the large pulley
Slowly twist the top pulley counter-clockwise while maintaining tension on the belt until the belt is completely on. This will require a bit of force
Lightly pressure wash or otherwise clean the inside of the belt guard and belt guard cover. This will reduce wear and damage on the new belt
Line up the cover of the belt guard and place each bolt in its respective hole
Firmly press the belt guard cover into the rubber molding of the belt guard case to ensure proper sealing
Tighten the bolts firmly with a 1/2 in socket and a 3/8 in drive ratchet
Congrats! Your belt is now replaced.
Please give this guide a favorite and like if you found it helpful and please leave your feedback in the comments below. Thank you and have a great rest of your day.
Uma outra pessoa concluiu este guia.
