Introdução
Use this guide to remove or replace the power cable on a Wacker M1500-120 REV 100 (2016) Concrete Vibrator.
O que você precisa
Pull up on the quick-disconnect handle to release the lock on the flex shaft.
Remove the flex shaft.
Use a T20 Torx screwdriver to remove the nineteen screws securing the two halves of the device housing.
Lay the device down onto its right side, screw holes facing up.
Remove the rear dust filter.
Use a pair of needle nose pliers to disconnect the black and white power wires from their terminals on the switch.
Use a T20 Torx screwdriver to remove the two screws securing the power cable clamp to the housing.
Lift the power cable assembly up and away from the device.
Slide the reinforcing sleeve up and off of the power cable.
