Ir para o conteúdo principal
Wacker Compactor Plate VP1550AW 2014 V-Belt Replacement
O que você precisa
  1. Wacker Compactor Plate VP1550AW 2014 V-Belt Replacement, Safety precautions: passo 1, imagem 1 %32 Wacker Compactor Plate VP1550AW 2014 V-Belt Replacement, Safety precautions: passo 1, imagem 2 %32
    • Before you begin, be sure that the engine is powered off and is cool to the touch.
    • Grab the plastic housing at the end of the spark plug wire.
    • Pull firmly to disconnect the wire from the spark plug.
  2. Wacker Compactor Plate VP1550AW 2014 V-Belt Replacement, Loosen the belt guard: passo 2, imagem 1 %32
    • Use a 1/2" socket and wrench to loosen the two bolts securing the belt guard.
    • The bolts are captive and should not be removed.
  3. Wacker Compactor Plate VP1550AW 2014 V-Belt Replacement, Remove the belt guard: passo 3, imagem 1 %32 Wacker Compactor Plate VP1550AW 2014 V-Belt Replacement, Remove the belt guard: passo 3, imagem 2 %32
    • Remove the belt guard.
  4. Wacker Compactor Plate VP1550AW 2014 V-Belt Replacement, Remove the drive belt: passo 4, imagem 1 %32 Wacker Compactor Plate VP1550AW 2014 V-Belt Replacement, Remove the drive belt: passo 4, imagem 2 %32 Wacker Compactor Plate VP1550AW 2014 V-Belt Replacement, Remove the drive belt: passo 4, imagem 3 %32
    • Use scissors or a blade to cut the drive belt.
    • Remove the drive belt.
  5. Wacker Compactor Plate VP1550AW 2014 V-Belt Replacement, Install a replacement belt: passo 5, imagem 1 %32
    • Loop the replacement belt onto the small pulley.
  6. Wacker Compactor Plate VP1550AW 2014 V-Belt Replacement: passo 6, imagem 1 %32 Wacker Compactor Plate VP1550AW 2014 V-Belt Replacement: passo 6, imagem 2 %32 Wacker Compactor Plate VP1550AW 2014 V-Belt Replacement: passo 6, imagem 3 %32
    • Replacing the belt poses a substantial pinching hazard. Wear safety gloves and be mindful where you position your fingers.
    • Guide the belt over the top of the clutch pulley.
    • Loop the belt underneath the pulley axle.
    • Rotate the pulley slowly and guide the built into the groove.
    • Getting the replacement belt back onto the drive pulley requires considerable strength.
Conclusão
Arthur Shi
Membro desde: 01/03/18
322.899 Reputação
Autoria de 793 guias
Equipe
iFixit Membro de iFixit
Staff
124 Membros
Autoria de 24.164 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 23
Ao todo: 3,735
