Ir para o conteúdo principal
Wacker 4-Stroke Rammer BS504AS REV 101 (2019) Bellows Replacement
O que você precisa
  1. Wacker 4-Stroke Rammer BS504AS REV 101 (2019) Bellows Replacement, Disconnect the spark plug wire: passo 1, imagem 1 %32 Wacker 4-Stroke Rammer BS504AS REV 101 (2019) Bellows Replacement, Disconnect the spark plug wire: passo 1, imagem 2 %32
    • Ensure the device is powered down and cool to the touch before starting your repair.
    • Firmly grip the base of the spark plug wire's connector and pull it away from the spark plug to disconnect it.
  2. Wacker 4-Stroke Rammer BS504AS REV 101 (2019) Bellows Replacement, Loosen the sight gauge: passo 2, imagem 1 %32
    • Use a 1-1/16 inch socket to break loose the oil sight gauge near the bottom of the device.
    • Do not fully remove the oil sight gauge yet with the device in this upright position.
    • The oil sight gauge doubles as the oil drain and fill plug.
  3. Wacker 4-Stroke Rammer BS504AS REV 101 (2019) Bellows Replacement, Prepare a drain pan: passo 3, imagem 1 %32
    • Lay the device down horizontally with the oil sight gauge facing down.
    • Position a shallow oil drain pan underneath the sight gauge.
  4. Wacker 4-Stroke Rammer BS504AS REV 101 (2019) Bellows Replacement, Drain the oil: passo 4, imagem 1 %32
    • Remove the oil sight gauge.
    • Let the oil drain until drips are infrequent.
    • Replace and retighten the oil sight gauge.
    • This model requires 0.7 liters of SAE 10W-40 oil.
  5. Wacker 4-Stroke Rammer BS504AS REV 101 (2019) Bellows Replacement, Support the device: passo 5, imagem 1 %32 Wacker 4-Stroke Rammer BS504AS REV 101 (2019) Bellows Replacement, Support the device: passo 5, imagem 2 %32
    • Flip the device onto the work surface such that the motor and handles face up.
    • Place two separate blocks of wood underneath the seam between the leg assembly and crankcase.
    • Once the two halves separate, each side will need to be supported.
  6. Wacker 4-Stroke Rammer BS504AS REV 101 (2019) Bellows Replacement, Remove the leg assembly bolts: passo 6, imagem 1 %32 Wacker 4-Stroke Rammer BS504AS REV 101 (2019) Bellows Replacement, Remove the leg assembly bolts: passo 6, imagem 2 %32
    • Use an 8 mm hex key socket to remove the four bolts securing the leg's guiding cylinder to the crankcase.
    • You may need to use an impact driver or breaker bar to break these bolts loose.
    • During reassembly, ensure each bolt has its accompanying lock washer.
  7. Wacker 4-Stroke Rammer BS504AS REV 101 (2019) Bellows Replacement, Begin to separate the halves: passo 7, imagem 1 %32 Wacker 4-Stroke Rammer BS504AS REV 101 (2019) Bellows Replacement, Begin to separate the halves: passo 7, imagem 2 %32
    • Pull the leg assembly away from the rest of the device.
    • Ensure each half stays adequately supported.
  8. Wacker 4-Stroke Rammer BS504AS REV 101 (2019) Bellows Replacement, Reveal the pin: passo 8, imagem 1 %32 Wacker 4-Stroke Rammer BS504AS REV 101 (2019) Bellows Replacement, Reveal the pin: passo 8, imagem 2 %32 Wacker 4-Stroke Rammer BS504AS REV 101 (2019) Bellows Replacement, Reveal the pin: passo 8, imagem 3 %32
    • Continue to separate the two halves by compressing the bellows until the nylon plug covering the piston pin is visible.
  9. Wacker 4-Stroke Rammer BS504AS REV 101 (2019) Bellows Replacement, Procedure tip: passo 9, imagem 1 %32 Wacker 4-Stroke Rammer BS504AS REV 101 (2019) Bellows Replacement, Procedure tip: passo 9, imagem 2 %32
    • Tip: To compress the bellows, insert a block of wood between the two halves and pivot the leg assembly off of the crankcase to compress the guide cylinder, revealing the pin.
  10. Wacker 4-Stroke Rammer BS504AS REV 101 (2019) Bellows Replacement, Remove the pin: passo 10, imagem 1 %32 Wacker 4-Stroke Rammer BS504AS REV 101 (2019) Bellows Replacement, Remove the pin: passo 10, imagem 2 %32 Wacker 4-Stroke Rammer BS504AS REV 101 (2019) Bellows Replacement, Remove the pin: passo 10, imagem 3 %32
    • Use an appropriately-sized punch and a ball-peen hammer to tap the pin out of its hole on the guide piston until it is no longer securing the connecting rod.
    • Once the piston and connecting rod are separated, the two halves become completely disconnected and will need to be adequately supported.
    • During reassembly, ensure that both nylon plugs are reinstalled and are flush with the surface of the guide piston.
  11. Wacker 4-Stroke Rammer BS504AS REV 101 (2019) Bellows Replacement, Remove the leg assembly: passo 11, imagem 1 %32 Wacker 4-Stroke Rammer BS504AS REV 101 (2019) Bellows Replacement, Remove the leg assembly: passo 11, imagem 2 %32
    • Remove the leg assembly from the crankcase.
  12. Wacker 4-Stroke Rammer BS504AS REV 101 (2019) Bellows Replacement, Completely remove the pin: passo 12, imagem 1 %32 Wacker 4-Stroke Rammer BS504AS REV 101 (2019) Bellows Replacement, Completely remove the pin: passo 12, imagem 2 %32
    • Use a punch and hammer to tap the pin out of the guide piston.
    • Once the pin is removed, the guide cylinder may spring up due to the compression of the bellows.
    • During reassembly, the bellows will need to be compressed to uncover the pin hole on the guide piston.
  13. Wacker 4-Stroke Rammer BS504AS REV 101 (2019) Bellows Replacement, Remove the hose clamps: passo 13, imagem 1 %32
    • Use a 13 mm socket or large flathead screwdriver to loosen the two hose clamp bolts securing the bellows to the leg assembly.
  14. Wacker 4-Stroke Rammer BS504AS REV 101 (2019) Bellows Replacement: passo 14, imagem 1 %32 Wacker 4-Stroke Rammer BS504AS REV 101 (2019) Bellows Replacement: passo 14, imagem 2 %32
    • Lower the bottom hose clamp away from the bellows and let it rest at the base of the leg assembly.
  15. Wacker 4-Stroke Rammer BS504AS REV 101 (2019) Bellows Replacement: passo 15, imagem 1 %32 Wacker 4-Stroke Rammer BS504AS REV 101 (2019) Bellows Replacement: passo 15, imagem 2 %32
    • Open the top hose clamp and pull it down, past the bellows, and let it rest at the base of the leg assembly.
  16. Wacker 4-Stroke Rammer BS504AS REV 101 (2019) Bellows Replacement, Remove the bellows from the guide cylinder: passo 16, imagem 1 %32 Wacker 4-Stroke Rammer BS504AS REV 101 (2019) Bellows Replacement, Remove the bellows from the guide cylinder: passo 16, imagem 2 %32 Wacker 4-Stroke Rammer BS504AS REV 101 (2019) Bellows Replacement, Remove the bellows from the guide cylinder: passo 16, imagem 3 %32
    • Use a rubber mallet to tap the bellows down and off of the top of the guide cylinder.
    • Tap around the entire circumference of the bellows, pulling one edge down at a time.
    • During reassembly, use the rubber mallet to tap the bellows into place onto the lip on the cylinder.
    • Once loose, pull the bellows off of the lip on the guide cylinder.
  17. Wacker 4-Stroke Rammer BS504AS REV 101 (2019) Bellows Replacement, Remove the guide cylinder: passo 17, imagem 1 %32 Wacker 4-Stroke Rammer BS504AS REV 101 (2019) Bellows Replacement, Remove the guide cylinder: passo 17, imagem 2 %32 Wacker 4-Stroke Rammer BS504AS REV 101 (2019) Bellows Replacement, Remove the guide cylinder: passo 17, imagem 3 %32
    • Lift up and remove the guide cylinder.
  18. Wacker 4-Stroke Rammer BS504AS REV 101 (2019) Bellows Replacement, Remove the bellows: passo 18, imagem 1 %32 Wacker 4-Stroke Rammer BS504AS REV 101 (2019) Bellows Replacement, Remove the bellows: passo 18, imagem 2 %32 Wacker 4-Stroke Rammer BS504AS REV 101 (2019) Bellows Replacement, Remove the bellows: passo 18, imagem 3 %32
    • Use a rubber mallet to tap the bellows up and off of the top of the protective pipe.
    • Tap around the entire circumference of the bellows, pulling one edge up at a time.
    • During reassembly, use the rubber mallet to tap the bellows into place onto the lip on the pipe.
    • Once loose, pull the bellows off of the lip on the protective pipe.
    • Remove the bellows.
Conclusão
After reassembly, tilt the device upright and check the oil level through the sight glass. The oil should cover 1/2 to 3/4 of the sight glass to be considered full. This model requires up to 0.7 liters of SAE 10W-40 oil.
Uma outra pessoa concluiu este guia.
Carsten Frauenheim
Membro desde: 03/10/20
136.031 Reputação
Autoria de 371 guias
Equipe
iFixit Membro de iFixit
Staff
Membros da 118
Autoria de 19.474 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 9
Duração total: 498
