Ir para o conteúdo principal
WRS315SDHW Water Filter Housing Replacement
O que você precisa
  1. WRS315SDHW Water Filter Housing Replacement, Safety precautions: passo 1, imagem 1 %32
    • Before you begin your repair, perform the following:
    • Turn off your main water supply
    • Unplug your device
  2. WRS315SDHW Water Filter Housing Replacement, Open the doors: passo 2, imagem 1 %32 WRS315SDHW Water Filter Housing Replacement, Open the doors: passo 2, imagem 2 %32 WRS315SDHW Water Filter Housing Replacement, Open the doors: passo 2, imagem 3 %32
    • Depending on your repair, open one or both doors.
  3. WRS315SDHW Water Filter Housing Replacement, Unfasten the front panel: passo 3, imagem 1 %32 WRS315SDHW Water Filter Housing Replacement, Unfasten the front panel: passo 3, imagem 2 %32 WRS315SDHW Water Filter Housing Replacement, Unfasten the front panel: passo 3, imagem 3 %32
    • Use a Phillips driver to remove the two 15.2 mm-long screws securing the front panel.
  4. WRS315SDHW Water Filter Housing Replacement, Remove the front panel: passo 4, imagem 1 %32 WRS315SDHW Water Filter Housing Replacement, Remove the front panel: passo 4, imagem 2 %32 WRS315SDHW Water Filter Housing Replacement, Remove the front panel: passo 4, imagem 3 %32
    • Pull the front panel straight off the chassis and remove it.
    • You may have to slightly open the water filter door to remove the front panel completely.
  5. WRS315SDHW Water Filter Housing Replacement, Unfasten the water filter housing: passo 5, imagem 1 %32
    • Use a 1/4 inch socket wrench to remove the two 18.9 mm-long screws securing the water filter housing.
    • Use a 1/4 inch socket wrench, or a flathead screwdriver, to remove the 15.6 mm-long screw securing the wire harness grounding wire.
  6. WRS315SDHW Water Filter Housing Replacement, Reposition the housing: passo 6, imagem 1 %32 WRS315SDHW Water Filter Housing Replacement, Reposition the housing: passo 6, imagem 2 %32
    • Pull the housing out of the chassis enough to access its left-hand water connections.
  7. WRS315SDHW Water Filter Housing Replacement, Remove the clips: passo 7, imagem 1 %32 WRS315SDHW Water Filter Housing Replacement, Remove the clips: passo 7, imagem 2 %32 WRS315SDHW Water Filter Housing Replacement, Remove the clips: passo 7, imagem 3 %32
    • Place a clean and dry rag under the water hoses.
    • Use needle nose pliers, or your fingers, to remove the blue clip on the bottom water hose.
    • Repeat for the red clip on the top water hose.
  8. WRS315SDHW Water Filter Housing Replacement, Disconnect the water hoses: passo 8, imagem 1 %32
    • Compress the plastic ring near the end of the water hose.
    • While compressing the ring, pull the hose away from the ring to disconnect it.
    • Repeat for the other water hose.
  9. WRS315SDHW Water Filter Housing Replacement, Remove the housing: passo 9, imagem 1 %32
    • Remove the water filter housing.
Conclusão
Repair didn’t go as planned? Ask our Answers community for help.
Uma outra pessoa concluiu este guia.
nicO
Membro desde: 04/14/15
15.927 Reputação
Autoria de 89 guias
Equipe
Global Fixers Membro de Global Fixers
Community
45 Membros
Autoria de 704 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 6
Ao todo: 117
