Ir para o conteúdo principal
WRS315SDHW Inlet Valve Assembly Replacement
O que você precisa
  1. WRS315SDHW Inlet Valve Assembly Replacement, Safety precautions: passo 1, imagem 1 %32
    • Before you begin your repair, perform the following:
    • Turn off your main water supply
    • Unplug your device
  2. WRS315SDHW Inlet Valve Assembly Replacement, Unfasten the rear panel: passo 2, imagem 1 %32 WRS315SDHW Inlet Valve Assembly Replacement, Unfasten the rear panel: passo 2, imagem 2 %32 WRS315SDHW Inlet Valve Assembly Replacement, Unfasten the rear panel: passo 2, imagem 3 %32
    • Use a 1/4 inch socket wrench, or a flathead screwdriver, to remove the seven 16.2 mm-long screws securing the rear panel.
    • Use a 1/4 inch socket wrench to loosen the screw securing the water hose enough for the rear panel to freely move.
  3. WRS315SDHW Inlet Valve Assembly Replacement, Remove the rear panel: passo 3, imagem 1 %32 WRS315SDHW Inlet Valve Assembly Replacement, Remove the rear panel: passo 3, imagem 2 %32 WRS315SDHW Inlet Valve Assembly Replacement, Remove the rear panel: passo 3, imagem 3 %32
    • Pull the rear panel off the chassis to remove it.
  4. WRS315SDHW Inlet Valve Assembly Replacement, Remove the clip: passo 4, imagem 1 %32 WRS315SDHW Inlet Valve Assembly Replacement, Remove the clip: passo 4, imagem 2 %32
    • Use needle nose pliers, or your fingers, to remove the plastic clip on the inlet valve assembly.
  5. WRS315SDHW Inlet Valve Assembly Replacement, Disconnect the front water hose: passo 5, imagem 1 %32 WRS315SDHW Inlet Valve Assembly Replacement, Disconnect the front water hose: passo 5, imagem 2 %32 WRS315SDHW Inlet Valve Assembly Replacement, Disconnect the front water hose: passo 5, imagem 3 %32
    • Push the plastic ring above the front water hose to release its clips.
    • As you push the ring, pull the water hose downward to disconnect it.
    • Repeat the disconnection procedure for the other water hose on the inlet valve assembly.
  6. WRS315SDHW Inlet Valve Assembly Replacement, Unfasten the inlet valve assembly: passo 6, imagem 1 %32
    • Use a 1/4 inch socket wrench to remove the two 15.6 mm-long screws securing the inlet valve assembly.
  7. WRS315SDHW Inlet Valve Assembly Replacement, Reposition the inlet valve assembly: passo 7, imagem 1 %32 WRS315SDHW Inlet Valve Assembly Replacement, Reposition the inlet valve assembly: passo 7, imagem 2 %32 WRS315SDHW Inlet Valve Assembly Replacement, Reposition the inlet valve assembly: passo 7, imagem 3 %32
    • Pull the inlet valve assembly off its slot in the chassis and rest it on the floor.
  8. WRS315SDHW Inlet Valve Assembly Replacement: passo 8, imagem 1 %32 WRS315SDHW Inlet Valve Assembly Replacement: passo 8, imagem 2 %32
    • Place a clean and dry rag under the inlet valve assembly before continuing.
  9. WRS315SDHW Inlet Valve Assembly Replacement, Remove the clip: passo 9, imagem 1 %32 WRS315SDHW Inlet Valve Assembly Replacement, Remove the clip: passo 9, imagem 2 %32
    • Use needle nose pliers, or your hands, to pull the blue clip off the rear water hose.
  10. WRS315SDHW Inlet Valve Assembly Replacement: passo 10, imagem 1 %32 WRS315SDHW Inlet Valve Assembly Replacement: passo 10, imagem 2 %32 WRS315SDHW Inlet Valve Assembly Replacement: passo 10, imagem 3 %32
    • Push the yellow plastic ring above the rear water hose to release its clips.
    • As you push the ring, pull the water hose away from the inlet valve assembly to disconnect it.
  11. WRS315SDHW Inlet Valve Assembly Replacement, Disconnect the assembly wire connector: passo 11, imagem 1 %32 WRS315SDHW Inlet Valve Assembly Replacement, Disconnect the assembly wire connector: passo 11, imagem 2 %32 WRS315SDHW Inlet Valve Assembly Replacement, Disconnect the assembly wire connector: passo 11, imagem 3 %32
    • Use a flathead screwdriver, or a similar tool, to disconnect the inlet valve assembly wire connector.
  12. WRS315SDHW Inlet Valve Assembly Replacement, Remove the inlet valve assembly: passo 12, imagem 1 %32
    • Remove the inlet valve assembly from the chassis.
Conclusão
Repair didn’t go as planned? Ask our Answers community for help.
Uma outra pessoa concluiu este guia.
nicO
Membro desde: 04/14/15
15.927 Reputação
Autoria de 89 guias
Equipe
Global Fixers Membro de Global Fixers
Community
45 Membros
Autoria de 702 guias
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 3
Ao todo: 181
