Ir para o conteúdo principal
WRS315SDHW Icemaker Assembly Replacement
O que você precisa
  1. WRS315SDHW Icemaker Assembly Replacement, Safety precautions: passo 1, imagem 1 %32
    • Before you begin your repair, perform the following:
    • Turn off your main water supply
    • Unplug your device
  2. WRS315SDHW Icemaker Assembly Replacement, Open the doors: passo 2, imagem 1 %32 WRS315SDHW Icemaker Assembly Replacement, Open the doors: passo 2, imagem 2 %32 WRS315SDHW Icemaker Assembly Replacement, Open the doors: passo 2, imagem 3 %32
    • Depending on your repair, open one or both doors.
  3. WRS315SDHW Icemaker Assembly Replacement, Remove the icemaker tray: passo 3, imagem 1 %32 WRS315SDHW Icemaker Assembly Replacement, Remove the icemaker tray: passo 3, imagem 2 %32
    • Pull the icemaker tray completely out of its slot in the chassis.
  4. WRS315SDHW Icemaker Assembly Replacement, Unfasten the icemaker assembly: passo 4, imagem 1 %32 WRS315SDHW Icemaker Assembly Replacement, Unfasten the icemaker assembly: passo 4, imagem 2 %32
    • Use a 1/4 inch socket wrench to remove the three screws securing the icemaker assembly (shown with the assembly removed):
    • Two 23.9 mm-long screws
    • One 16.7 mm-long screw
  5. WRS315SDHW Icemaker Assembly Replacement, Reposition the icemaker assembly: passo 5, imagem 1 %32 WRS315SDHW Icemaker Assembly Replacement, Reposition the icemaker assembly: passo 5, imagem 2 %32 WRS315SDHW Icemaker Assembly Replacement, Reposition the icemaker assembly: passo 5, imagem 3 %32
    • Pull the icemaker assembly toward the right edge of the refrigerator to release it from its slot in the chassis.
    • Let the icemaker assembly hang to access its connector.
  6. WRS315SDHW Icemaker Assembly Replacement, Disconnect the icemaker assembly: passo 6, imagem 1 %32 WRS315SDHW Icemaker Assembly Replacement, Disconnect the icemaker assembly: passo 6, imagem 2 %32 WRS315SDHW Icemaker Assembly Replacement, Disconnect the icemaker assembly: passo 6, imagem 3 %32
    • Disconnect the spade connector attached to the icemaker assembly.
  7. WRS315SDHW Icemaker Assembly Replacement, Remove the icemaker assembly: passo 7, imagem 1 %32
    • Remove the icemaker assembly.
Conclusão
Repair didn’t go as planned? Ask our Answers community for help.
Uma outra pessoa concluiu este guia.
nicO
Membro desde: 04/14/15
15.987 Reputação
Autoria de 89 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 8
Últimos 30 dias: 31
Ao todo: 537
