Ir para o conteúdo principal
WRS315SDHW Door Seal Replacement
O que você precisa
  1. WRS315SDHW Door Seal Replacement, Safety precautions: passo 1, imagem 1 %32
    • Before you begin your repair, perform the following:
    • Turn off your main water supply
    • Unplug your device
  2. WRS315SDHW Door Seal Replacement, Open the doors: passo 2, imagem 1 %32 WRS315SDHW Door Seal Replacement, Open the doors: passo 2, imagem 2 %32 WRS315SDHW Door Seal Replacement, Open the doors: passo 2, imagem 3 %32
    • Depending on your repair, open one or both doors.
  3. WRS315SDHW Door Seal Replacement, Disconnect the door seal: passo 3, imagem 1 %32 WRS315SDHW Door Seal Replacement, Disconnect the door seal: passo 3, imagem 2 %32 WRS315SDHW Door Seal Replacement, Disconnect the door seal: passo 3, imagem 3 %32
    • Insert an opening tool, or a similar tool, between the door frame and the seal.
    • Pry up to separate the seal from its groove on the frame.
    • This may take significant force.
  4. WRS315SDHW Door Seal Replacement, Remove the door seal: passo 4, imagem 1 %32 WRS315SDHW Door Seal Replacement, Remove the door seal: passo 4, imagem 2 %32 WRS315SDHW Door Seal Replacement, Remove the door seal: passo 4, imagem 3 %32
    • Use your hand and the opening tool to peel the door seal away from the frame.
    • Repeat this process for the perimeter of the door seal until the seal is completely separated.
  5. WRS315SDHW Door Seal Replacement, Only the door seal remains: passo 5, imagem 1 %32 WRS315SDHW Door Seal Replacement, Only the door seal remains: passo 5, imagem 2 %32 WRS315SDHW Door Seal Replacement, Only the door seal remains: passo 5, imagem 3 %32
    • You're now left with the door seal.
    • During reassembly, perform the following:
    • Use a Jimmy, or a similar tool, to remove any sealing foam in the door frame groove.
    • Use a mild cleaning solution to fully clean the groove.
    • Reinstall your door by attaching the top edge first, then wrapping the seal around the frame's perimeter.
    • You'll hear the gasket lock into the seam.
    • You may have to stretch the seal a few inches at the final edge.
  6. WRS315SDHW Door Seal Replacement, Perform a seal test: passo 6, imagem 1 %32 WRS315SDHW Door Seal Replacement, Perform a seal test: passo 6, imagem 2 %32 WRS315SDHW Door Seal Replacement, Perform a seal test: passo 6, imagem 3 %32
    • To test if your replacement door seal is working, perform the following:
    • Open the door slightly and insert a clean, flat bill between the door seal and the frame.
    • Close the door and slowly drag the bill away from the device.
    • If the seal is tight, then you should feel a moderate amount of resistance in the bill.
Conclusão
Repair didn’t go as planned? Ask our Answers community for help.
Uma outra pessoa concluiu este guia.
nicO
Membro desde: 04/14/15
15.927 Reputação
Autoria de 89 guias
Equipe
Global Fixers Membro de Global Fixers
Community
45 Membros
Autoria de 702 guias
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Ao todo: 91
