Ir para o conteúdo principal
WRS315SDHW Door Light Replacement
O que você precisa
  1. WRS315SDHW Door Light Replacement, Open the doors: passo 1, imagem 1 %32 WRS315SDHW Door Light Replacement, Open the doors: passo 1, imagem 2 %32 WRS315SDHW Door Light Replacement, Open the doors: passo 1, imagem 3 %32
    • Depending on your repair, open one or both doors.
  2. WRS315SDHW Door Light Replacement, Unclip the door light: passo 2, imagem 1 %32 WRS315SDHW Door Light Replacement, Unclip the door light: passo 2, imagem 2 %32
    • Be careful during this step, as it's easy to scratch the interior of the fridge or crack cold and brittle plastic.
    • Carefully insert a flathead screwdriver, or a similar tool, between the door light and the chassis.
    • Pry up to separate the door light enough so you can grip it with your fingers.
  3. WRS315SDHW Door Light Replacement: passo 3, imagem 1 %32 WRS315SDHW Door Light Replacement: passo 3, imagem 2 %32 WRS315SDHW Door Light Replacement: passo 3, imagem 3 %32
    • Tilt the door light toward the right edge of the refrigerator to completely release its plastic clips.
    • Pull the light down to expose its connectors.
  4. WRS315SDHW Door Light Replacement: passo 4, imagem 1 %32 WRS315SDHW Door Light Replacement: passo 4, imagem 2 %32 WRS315SDHW Door Light Replacement: passo 4, imagem 3 %32
    • Disconnect the two spade connectors attached to the door light.
    • Remove the door light.
Conclusão
Repair didn’t go as planned? Ask our Answers community for help.
Uma outra pessoa concluiu este guia.
nicO
Membro desde: 04/14/15
15.945 Reputação
Autoria de 89 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 10
Ao todo: 225
