Ir para o conteúdo principal
WRS315SDHW Condenser Fan Replacement
O que você precisa
  1. WRS315SDHW Condenser Fan Replacement, Safety precautions: passo 1, imagem 1 %32
    • Before you begin your repair, perform the following:
    • Turn off your main water supply
    • Unplug your device
  2. WRS315SDHW Condenser Fan Replacement, Unfasten the rear panel: passo 2, imagem 1 %32 WRS315SDHW Condenser Fan Replacement, Unfasten the rear panel: passo 2, imagem 2 %32 WRS315SDHW Condenser Fan Replacement, Unfasten the rear panel: passo 2, imagem 3 %32
    • Use a 1/4 inch socket wrench, or a flathead screwdriver, to remove the seven 16.2 mm-long screws securing the rear panel.
    • Use a 1/4 inch socket wrench to loosen the screw securing the water hose enough for the rear panel to freely move.
  3. WRS315SDHW Condenser Fan Replacement, Remove the rear panel: passo 3, imagem 1 %32 WRS315SDHW Condenser Fan Replacement, Remove the rear panel: passo 3, imagem 2 %32 WRS315SDHW Condenser Fan Replacement, Remove the rear panel: passo 3, imagem 3 %32
    • Pull the rear panel off the chassis to remove it.
  4. WRS315SDHW Condenser Fan Replacement, Disconnect the condenser fan: passo 4, imagem 1 %32 WRS315SDHW Condenser Fan Replacement, Disconnect the condenser fan: passo 4, imagem 2 %32
    • Press the tab on the condenser fan cable connector to unclip it.
    • Pull the connector straight out of its slot to remove it.
  5. WRS315SDHW Condenser Fan Replacement, Remove the condenser fan: passo 5, imagem 1 %32 WRS315SDHW Condenser Fan Replacement, Remove the condenser fan: passo 5, imagem 2 %32 WRS315SDHW Condenser Fan Replacement, Remove the condenser fan: passo 5, imagem 3 %32
    • Put on gloves before continuing, as the sheet metal and the fan itself are sharp.
    • Pull the condenser fan straight off its peg to remove it.
  6. WRS315SDHW Condenser Fan Replacement, Unfasten the condenser fan motor: passo 6, imagem 1 %32
    • Use a 1/4 inch socket wrench to remove the four 16.5 mm-long screws securing the condenser fan motor to the chassis.
  7. WRS315SDHW Condenser Fan Replacement, Remove the motor: passo 7, imagem 1 %32 WRS315SDHW Condenser Fan Replacement, Remove the motor: passo 7, imagem 2 %32 WRS315SDHW Condenser Fan Replacement, Remove the motor: passo 7, imagem 3 %32
    • Rotate the motor housing through its slot in the chassis.
    • Remove the motor.
Conclusão
Repair didn’t go as planned? Ask our Answers community for help.
Uma outra pessoa concluiu este guia.
nicO
Membro desde: 04/14/15
15.945 Reputação
Autoria de 89 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 5
Ao todo: 223
