Ir para o conteúdo principal
WLAN / Bluetooth Card Replacement
O que você precisa
  1. WLAN / Bluetooth Card Replacement, Battery: passo 1, imagem 1 %32 WLAN / Bluetooth Card Replacement, Battery: passo 1, imagem 2 %32 WLAN / Bluetooth Card Replacement, Battery: passo 1, imagem 3 %32
    • Unlock the battery latch on the right.
    • Unlock the battery lock on the left.
    • Remove the battery pack from its slot.
  2. WLAN / Bluetooth Card Replacement, Access to Components 2: passo 2, imagem 1 %32 WLAN / Bluetooth Card Replacement, Access to Components 2: passo 2, imagem 2 %32 WLAN / Bluetooth Card Replacement, Access to Components 2: passo 2, imagem 3 %32
    • Using the Philips # 0 screwdriver, unscrew the 2 screws of the top cover
    • Check the marks indicating the direction in which the cover must be removed.
    • Remove the bottom cover by removing it in the direction of the markers.
  3. WLAN / Bluetooth Card Replacement: passo 3, imagem 1 %32
    • Then appear the other components of the Laptop.
  4. WLAN / Bluetooth Card Replacement, WLAN / Bluetooth card: passo 4, imagem 1 %32 WLAN / Bluetooth Card Replacement, WLAN / Bluetooth card: passo 4, imagem 2 %32 WLAN / Bluetooth Card Replacement, WLAN / Bluetooth card: passo 4, imagem 3 %32
    • Here is the WLAN Chipset / Bluetooth
    • Gently unplug the MAIN and AUX antennas.
    • Unscrew the fixing screw with Philips # 0 screwdriver.
  5. WLAN / Bluetooth Card Replacement: passo 5, imagem 1 %32 WLAN / Bluetooth Card Replacement: passo 5, imagem 2 %32
    • Slightly lift the chipset and remove it from the mSATA connector.
    • Here is the chipset outside of its location.
Conclusão
To reassemble your device follow the following instructions in reverse order
Um agradecimento especial a esses tradutores:
fr en
100%
irlanda está nos ajudando a consertar o mundo! Quer contribuir?
Comece a traduzir ›
Felice Suglia
Membro desde: 06/15/13
33.538 Reputação
Autoria de 283 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 16
Ao todo: 571
