Ir para o conteúdo principal
Vulcan Venture II VNB14002IE Motherboard Replacement
O que você precisa
  1. Vulcan Venture II VNB14002IE Motherboard Replacement, Back Panel: passo 1, imagem 1 %32
    • Use a J00 screwdriver to unscrew the 10 back-plate screws.
  2. Vulcan Venture II VNB14002IE Motherboard Replacement: passo 2, imagem 1 %32
    • Gently separate the back panel from the laptop.
  3. Vulcan Venture II VNB14002IE Motherboard Replacement, Motherboard: passo 3, imagem 1 %32
    • Disconnect the 4 ribbon cables connected to the motherboard by carefully lifting up the black bar attached to the housing. Slowly slide the cable out once released.
    • Disconnect the wire connected to the motherboard.
    • Disconnect the battery by gently pulling out the cable connected to the board.
  4. Vulcan Venture II VNB14002IE Motherboard Replacement: passo 4, imagem 1 %32
    • Remove the screws located in the corners of the board using a J00 screwdriver.
  5. Vulcan Venture II VNB14002IE Motherboard Replacement: passo 5, imagem 1 %32
    • Gently lift the board out of the housing without any cables still connected to the board.
    • Picture shows the housing of the motherboard after the motherboard has been removed.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 13
Duração total: 430
