Ir para o conteúdo principal
Vulcan Venture II VNB14002IE I/O Board Replacement
O que você precisa
  1. Vulcan Venture II VNB14002IE I/O Board Replacement, Back Panel: passo 1, imagem 1 %32
    • Use a J00 screwdriver to unscrew the 10 back-plate screws.
  2. Vulcan Venture II VNB14002IE I/O Board Replacement: passo 2, imagem 1 %32
    • Gently separate the back panel from the laptop.
  3. Vulcan Venture II VNB14002IE I/O Board Replacement, I/O Board: passo 3, imagem 1 %32
    • Locate the IO board on the back panel.
  4. Vulcan Venture II VNB14002IE I/O Board Replacement: passo 4, imagem 1 %32 Vulcan Venture II VNB14002IE I/O Board Replacement: passo 4, imagem 2 %32
    • Locate the ribbon connector on the IO board, and lift the black bar closest the the ribbon.
    • Pull the ribbon cable away from the connector, releasing it.
  5. Vulcan Venture II VNB14002IE I/O Board Replacement: passo 5, imagem 1 %32 Vulcan Venture II VNB14002IE I/O Board Replacement: passo 5, imagem 2 %32
    • Locate the screws on the IO panel, and use the J00+ bit to unscrew them.
  6. Vulcan Venture II VNB14002IE I/O Board Replacement: passo 6, imagem 1 %32
    • The IO Board is now safe to remove from the computer.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 7
Duração total: 512
