Ir para o conteúdo principal
VuPoint DC-ST210-VP LCD Screen Replacement
O que você precisa
    1. VuPoint DC-ST210-VP LCD Screen Replacement, Turn Off/Remove Batteries: passo 1, imagem 1 %32
      • Hold the on/off button for 3 seconds until the screen is black.
      • Remove batteries by placing thumb on battery plate cover sliding it down to expose batteries.
      • Turn camera upside down to allow the batteries to fall out.
      Pergunte ao FixBot
      Comentar
    2. VuPoint DC-ST210-VP LCD Screen Replacement, Remove Screws: passo 2, imagem 1 %32 VuPoint DC-ST210-VP LCD Screen Replacement, Remove Screws: passo 2, imagem 2 %32 VuPoint DC-ST210-VP LCD Screen Replacement, Remove Screws: passo 2, imagem 3 %32
      • There are 5 (4.5mm in length) screws on the sides of the camera that need to be removed. Use a Phillips #000 screwdriver to remove all screws.
      • Remove 2 screws on the right side of the camera, and store them on a magnetic mat.
      • Remove 2 screws on the bottom of the camera, and store them on a magnetic mat.
      • Remove 1 screw on the left side of the camera, and store it on a magnetic mat.
      Pergunte ao FixBot
      Comentar
    3. VuPoint DC-ST210-VP LCD Screen Replacement, Pry Backplate Off: passo 3, imagem 1 %32 VuPoint DC-ST210-VP LCD Screen Replacement, Pry Backplate Off: passo 3, imagem 2 %32
      • Using a prying tool or fingernail, gently separate the back plate from the front plate, exposing the inside of the camera.
      Pergunte ao FixBot
      Comentar
    1. VuPoint DC-ST210-VP LCD Screen Replacement, Remove Circuit Board Screws: passo 4, imagem 1 %32
      Ferramenta utilizada neste passo:
      Magnetic Project Mat
      $19.95
      • Using a Phillips #00 screwdriver, remove the 5 (3.5mm in length) screws shown to the left.
      • Remember to place small screws on magnetic mat or in a container.
      Pergunte ao FixBot
      Comentar
    2. VuPoint DC-ST210-VP LCD Screen Replacement, Seperate Circuit Board: passo 5, imagem 1 %32 VuPoint DC-ST210-VP LCD Screen Replacement, Seperate Circuit Board: passo 5, imagem 2 %32 VuPoint DC-ST210-VP LCD Screen Replacement, Seperate Circuit Board: passo 5, imagem 3 %32
      • Using a pry tool or fingernail, gently pry the circuit board from the base.
      • Gently lift the lower right hand corner of the circuit board, separating it from the base.
      Pergunte ao FixBot
      Comentar
    3. VuPoint DC-ST210-VP LCD Screen Replacement, Remove LCD from Connector: passo 6, imagem 1 %32 VuPoint DC-ST210-VP LCD Screen Replacement, Remove LCD from Connector: passo 6, imagem 2 %32 VuPoint DC-ST210-VP LCD Screen Replacement, Remove LCD from Connector: passo 6, imagem 3 %32
      • Locate LCD and gently bend it back to reveal ribbon cable connector.
      • Using small screw driver or tweezers gently slide the edges of the ribbon lock towards the direction of the cable.
      • Once the lock is opened, use tweezers to slide the ribbon cable from the connector.
      • Replace LCD as needed and repeat steps in reverse to reassemble.
      Pergunte ao FixBot
      Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Equipe
Baylor, Team 8-15, Williams Fall 2014 Membro de Baylor, Team 8-15, Williams Fall 2014
BU-WILLIAMS-F14S8G15
3 Membros
Autoria de 5 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 11
Últimos 30 dias: 32
Ao todo: 786
