Ir para o conteúdo principal
VuPoint DC-ST210-VP Battery Door Cover Replacement
O que você precisa
  1. VuPoint DC-ST210-VP Battery Door Cover Replacement, Turn Off/Remove Batteries: passo 1, imagem 1 %32
    • Hold the on/off button for 3 seconds until the screen is black.
    • Remove batteries by placing thumb on battery plate cover sliding it down to expose batteries.
    • Turn camera upside down to allow the batteries to fall out.
  2. VuPoint DC-ST210-VP Battery Door Cover Replacement, Remove Screws: passo 2, imagem 1 %32 VuPoint DC-ST210-VP Battery Door Cover Replacement, Remove Screws: passo 2, imagem 2 %32 VuPoint DC-ST210-VP Battery Door Cover Replacement, Remove Screws: passo 2, imagem 3 %32
    • There are 5 (4.5mm in length) screws on the sides of the camera that need to be removed. Use a Phillips #000 screwdriver to remove all screws.
    • Remove 2 screws on the right side of the camera, and store them on a magnetic mat.
    • Remove 2 screws on the bottom of the camera, and store them on a magnetic mat.
    • Remove 1 screw on the left side of the camera, and store it on a magnetic mat.
  3. VuPoint DC-ST210-VP Battery Door Cover Replacement, Pry Backplate Off: passo 3, imagem 1 %32 VuPoint DC-ST210-VP Battery Door Cover Replacement, Pry Backplate Off: passo 3, imagem 2 %32
    • Using a prying tool or fingernail, gently separate the back plate from the front plate, exposing the inside of the camera.
  4. VuPoint DC-ST210-VP Battery Door Cover Replacement, Remove Battery Case Screw: passo 4, imagem 1 %32
    • Remove the 4.5mm screw with the iFixit ph#00 screwdriver
  5. VuPoint DC-ST210-VP Battery Door Cover Replacement, Open the Battery Case: passo 5, imagem 1 %32 VuPoint DC-ST210-VP Battery Door Cover Replacement, Open the Battery Case: passo 5, imagem 2 %32
    • With your fingers, gently pull the two pieces of the battery case apart. At this point, the battery door should be exposed
  6. VuPoint DC-ST210-VP Battery Door Cover Replacement, Remove the Battery Cover: passo 6, imagem 1 %32
    • With your fingers, gently remove the battery door.
    • Now you are free to repair or replace the battery door! Follow these steps in reverse order to reassemble the camera.
Conclusão
Elise Brown
Membro desde: 10/26/14
70 Reputação
Autoria de 2 guias
Equipe
Baylor, Team 8-15, Williams Fall 2014 Membro de Baylor, Team 8-15, Williams Fall 2014
BU-WILLIAMS-F14S8G15
3 Membros
Autoria de 5 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 10
Ao todo: 507
