Ir para o conteúdo principal
Vtech kidizoom camera disassembly
O que você precisa
    1. Vtech kidizoom camera disassembly, Vtech kidizoom camera disassembly: passo 1, imagem 1 %32 Vtech kidizoom camera disassembly, Vtech kidizoom camera disassembly: passo 1, imagem 2 %32 Vtech kidizoom camera disassembly, Vtech kidizoom camera disassembly: passo 1, imagem 3 %32
      • Camera
      Pergunte ao FixBot
      Comentar
    2. Vtech kidizoom camera disassembly: passo 2, imagem 1 %32 Vtech kidizoom camera disassembly: passo 2, imagem 2 %32 Vtech kidizoom camera disassembly: passo 2, imagem 3 %32
      • push and open
      Pergunte ao FixBot
      Comentar
    3. Vtech kidizoom camera disassembly: passo 3, imagem 1 %32 Vtech kidizoom camera disassembly: passo 3, imagem 2 %32 Vtech kidizoom camera disassembly: passo 3, imagem 3 %32
      • Insérer un commentaire.
      Pergunte ao FixBot
      Comentar
    4. Vtech kidizoom camera disassembly: passo 4, imagem 1 %32 Vtech kidizoom camera disassembly: passo 4, imagem 2 %32 Vtech kidizoom camera disassembly: passo 4, imagem 3 %32
      Pergunte ao FixBot
      Comentar
    5. Vtech kidizoom camera disassembly: passo 5, imagem 1 %32
      Pergunte ao FixBot
      Comentar
Conclusão
Pour réassembler votre appareil, suivez les instructions dans l'ordre inverse.
13 outras pessoas executaram este guia.
olixcomtest
Membro desde: 11/06/16
377 Reputação
Autoria de 1 guia
5Comentários do guia
In the very first step be aware that the you just need to remove the paper ring. In the photo above this is pink and on mine it was orange.
I made the mistake of thinking I had to use some force with a screwdriver, to remove the ring on the front, which resulted in me scratching the chrome ring.
Once you have removed the paper ring, you can see the screws (or they may be under the left over sticky backing to the paper but are easy to find).
These photos were extremely helpful and I was able to repair the camera.
The problem with mine, was that it would not switch on. We replaced the batteries, but still no good.
After using the above photos, I opened the camera and discovered that one of the two cables to one of the battery holders, had come loose.
In the process of resoldering the broken cable, the second battery cable also came off … mainly due to the use of VERY thin wire and minimum solder.
Anyway, the camera is now working again and my son is very happy.
Chris - Responder Compartilhar
Thank you! It worked great with the Kidizoom Touch 5.0, Same principle. The Trigger was Stuck and with your instruction i was able to Open and fix it!
Flo - Responder Compartilhar
Thanks! I had the newer Kidzoom touch 5.0 model. It works similar but after the same principle: First remove the camera objective ring. I could repair the (mechanical) damage…
Klausklaus - Responder Compartilhar
Thanks a lot, also in my case the trigger button of the kidizoom touch 5.0 was stuck. I followed the instruction and was able to fix it. Thereby I scratched a bit the silver ring. This may could be prevented if the locator of the notches are known/considered while trying to remove the outer ring.
DAVID - Responder Compartilhar
Hi, has anyone any experience of taking the Vtech Kidizoom Action Cam HD apart mine charges but will not switch on (loose wire i suspect) but i can't see how to disassemble. Cheers Alan.
Alan Mitchell - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 72
Últimos 7 dias: 128
Últimos 30 dias: 345
Ao todo: 19,912
