Ir para o conteúdo principal
Vtech Touch and Swipe Baby Phone Power Switch Replacement
O que você precisa
  1. Vtech Touch and Swipe Baby Phone Power Switch Replacement, Battery: passo 1, imagem 1 %32 Vtech Touch and Swipe Baby Phone Power Switch Replacement, Battery: passo 1, imagem 2 %32
    • Using a Phillips #1 screwdriver, remove the 4.8mm screw on the battery cover by twisting the screwdriver counter-clockwise.
  2. Vtech Touch and Swipe Baby Phone Power Switch Replacement: passo 2, imagem 1 %32 Vtech Touch and Swipe Baby Phone Power Switch Replacement: passo 2, imagem 2 %32 Vtech Touch and Swipe Baby Phone Power Switch Replacement: passo 2, imagem 3 %32
    • Remove the two AAA batteries by pulling on one end of the battery and lifting it straight out.
  3. Vtech Touch and Swipe Baby Phone Power Switch Replacement: passo 3, imagem 1 %32 Vtech Touch and Swipe Baby Phone Power Switch Replacement: passo 3, imagem 2 %32 Vtech Touch and Swipe Baby Phone Power Switch Replacement: passo 3, imagem 3 %32
    • When reassembling, align the notch on the battery panel with the slot on the phone.
  4. Vtech Touch and Swipe Baby Phone Power Switch Replacement, Power Switch: passo 4, imagem 1 %32 Vtech Touch and Swipe Baby Phone Power Switch Replacement, Power Switch: passo 4, imagem 2 %32
    • Remove 4 13.8mm screws holding the device back using a Phillips #1 screw driver.
  5. Vtech Touch and Swipe Baby Phone Power Switch Replacement: passo 5, imagem 1 %32 Vtech Touch and Swipe Baby Phone Power Switch Replacement: passo 5, imagem 2 %32 Vtech Touch and Swipe Baby Phone Power Switch Replacement: passo 5, imagem 3 %32
    • Lift directly up to remove the switch and lay the wire down to the side.
    • Once the switch has been taken out you can remove the switch's casing.
Conclusão
Uma outra pessoa concluiu este guia.
tellocordova
Membro desde: 09/04/15
342 Reputação
Autoria de 2 guias
Equipe
USF Tampa, Team 2-4, Sullivan Fall 2015 Membro de USF Tampa, Team 2-4, Sullivan Fall 2015
USFT-SULLIVAN-F15S2G4
Membros da 3
Autoria de 6 guias
2 comentários
Good work.
I have done it the same way,
the wire at the switch was bad soldered,
but it was easy to repair it and i soldered it new.
Nice.
Schwarzstein - Responder
My baby’s phone keeps turning itself off. The switch is in the ON position but it keeps turning OFF and singing the off song. I have opened the phone and even held the switch to ON but it still keeps turning OFF even without the switch moving. Any suggestions?
shakinsher - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 9
Duração total: 603
