Ir para o conteúdo principal
Vtech Kidizoom Smart Watch DX Faceplate Replacement
O que você precisa
  1. Vtech Kidizoom Smart Watch DX Faceplate Replacement, Faceplate: passo 1, imagem 1 %32
    • Flip the watch so that the screen faces upward.
  2. Vtech Kidizoom Smart Watch DX Faceplate Replacement: passo 2, imagem 1 %32
    • Use a plastic opening tool to gently pry the edges of the faceplate away from the watch.
    • You may hear some popping sounds as you are removing the faceplate. This is normal.
  3. Vtech Kidizoom Smart Watch DX Faceplate Replacement: passo 3, imagem 1 %32
    • Pull the faceplate fully apart from the watch.
Conclusão
4 outras pessoas executaram este guia.
Jordan RiberSmith
Membro desde: 01/20/16
755 Reputação
Autoria de 2 guias
Equipe
USF Tampa, Team 10-6, Remmell Spring 2016 Membro de USF Tampa, Team 10-6, Remmell Spring 2016
USFT-REMMELL-S16S10G6
Membros da 4
Autoria de 12 guias
6 comentários
Where can I get a new faceplate???
Eileen Osborne - Responder
Yes even I have same Question ..Where do I get this faceplate??
Manisha Divekar - Responder
Did you get an answer on you question. I need a faceplate too
Please advise
michele - Responder
Where can I get a replacement faceplate
cram66bum - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 25
Duração total: 6,172
