Ir para o conteúdo principal
Vtech Kidibeats Drum Set Battery Replacement
O que você precisa
  1. Vtech Kidibeats Drum Set Battery Replacement, Battery: passo 1, imagem 1 %32
    • Locate the battery panel that is centered between the three leg supports at the bottom of the drum set.
  2. Vtech Kidibeats Drum Set Battery Replacement: passo 2, imagem 1 %32
    • To remove the battery panel, loosen the 10 mm panel screw using a flathead 4.0 screwdriver.
    • You can also use a small coin to loosen the screw.
  3. Vtech Kidibeats Drum Set Battery Replacement: passo 3, imagem 1 %32
    • Using your fingers, pry open and remove the back battery panel.
  4. Vtech Kidibeats Drum Set Battery Replacement: passo 4, imagem 1 %32
    • Use your fingers to remove each battery from its housing.
    • When inserting the new batteries, remember to match them according to the image displayed on the battery panel.
Conclusão
Aaron Klementowski
Membro desde: 02/09/16
820 Reputação
Autoria de 6 guias
Equipe
USF Tampa, Team 2-8, Cagle Spring 2016 Membro de USF Tampa, Team 2-8, Cagle Spring 2016
USFT-CAGLE-S16S2G8
Membros da 2
Autoria de 12 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 21
Duração total: 938
