Ir para o conteúdo principal
Vtech Innotab 3 Button Replacement
O que você precisa
  1. Vtech Innotab 3 Button Replacement, Rear Panel: passo 1, imagem 1 %32 Vtech Innotab 3 Button Replacement, Rear Panel: passo 1, imagem 2 %32 Vtech Innotab 3 Button Replacement, Rear Panel: passo 1, imagem 3 %32
    • Slide the battery compartment door lock down.
    • While still holding the battery compartment lock down, slide the two battery doors outwards on either side of the device.
    • Carefully remove the batteries from the battery compartment.
    • The standard option for the InnoTab 3 is four AA batteries. Vtech also offers a rechargeable battery online, but both battery options are removed from the device the same way.
  2. Vtech Innotab 3 Button Replacement: passo 2, imagem 1 %32
    • Remove the six 7.6mm screws found in the battery compartment using a PH00 screwdriver.
  3. Vtech Innotab 3 Button Replacement: passo 3, imagem 1 %32 Vtech Innotab 3 Button Replacement: passo 3, imagem 2 %32 Vtech Innotab 3 Button Replacement: passo 3, imagem 3 %32
    • There are three hidden screws on the back of the device, two at the top and one near the bottom.
    • Using a nylon or metal spudger, remove the three caps that hide the screws.
    • Remove the 5mm screw near the bottom and the two 7.6mm at the top using a PH00 screwdriver.
  4. Vtech Innotab 3 Button Replacement: passo 4, imagem 1 %32
    • Carefully separate the back panel from the front panel revealing the motherboard connected to the front panel.
  5. Vtech Innotab 3 Button Replacement, Button Repair: passo 5, imagem 1 %32 Vtech Innotab 3 Button Replacement, Button Repair: passo 5, imagem 2 %32 Vtech Innotab 3 Button Replacement, Button Repair: passo 5, imagem 3 %32
    • Remove the four 7.6 mm screws using a PH00 screwdriver.
    • Lift the circuit board up to give yourself room to remove the buttons.
  6. Vtech Innotab 3 Button Replacement: passo 6, imagem 1 %32 Vtech Innotab 3 Button Replacement: passo 6, imagem 2 %32 Vtech Innotab 3 Button Replacement: passo 6, imagem 3 %32
    • Using a nylon or metal spudger, lift up the buttons to remove them from their holding. they should just pop out of place.
    • The buttons are joined together in pairs, be sure not to break them apart during removal.
Conclusão
Zach Diviney
Membro desde: 03/11/15
419 Reputação
Autoria de 4 guias
Equipe
Colorado Springs, Team 5-4, Panko Spring 2015 Membro de Colorado Springs, Team 5-4, Panko Spring 2015
UCCS-PANKO-S15S5G4
Membros da 3
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 5
Últimos 30 dias: 12
Duração total: 549
