Ir para o conteúdo principal
Vtech InnoTab 3S Speaker Replacement
O que você precisa
  1. Vtech InnoTab 3S Speaker Replacement, Rear Panel: passo 1, imagem 1 %32 Vtech InnoTab 3S Speaker Replacement, Rear Panel: passo 1, imagem 2 %32 Vtech InnoTab 3S Speaker Replacement, Rear Panel: passo 1, imagem 3 %32
    • While holding the battery compartment locks down, slide the two battery doors outwards from the sides of the device.
    • Remove the batteries from the device.
  2. Vtech InnoTab 3S Speaker Replacement: passo 2, imagem 1 %32 Vtech InnoTab 3S Speaker Replacement: passo 2, imagem 2 %32
    • Remove six 7 mm screws from the interior of the battery compartment using a Phillips #1 screwdriver.
  3. Vtech InnoTab 3S Speaker Replacement: passo 3, imagem 1 %32 Vtech InnoTab 3S Speaker Replacement: passo 3, imagem 2 %32 Vtech InnoTab 3S Speaker Replacement: passo 3, imagem 3 %32
    • Using a nylon spudger, remove the five caps that hide the screws.
    • Potential for device damage: Be careful not to scrape the plastic from the device using the spudger.
    • When removing the caps, hold the spudger vertical to the board to make removal easier. Also try to push in with your spudger pointing towards the bottom of the device.
    • Remove the five 5 mm Phillips #1 screws from the rear panel of the device.
  4. Vtech InnoTab 3S Speaker Replacement: passo 4, imagem 1 %32
    • Carefully remove the rear panel from the front panel of the device.
    • Once the rear panel is removed, you'll be able to see the motherboard and other components within the Vtech InnoTab 3s.
  5. Vtech InnoTab 3S Speaker Replacement, Motherboard: passo 5, imagem 1 %32 Vtech InnoTab 3S Speaker Replacement, Motherboard: passo 5, imagem 2 %32
    • Remove the six screws that secure the motherboard to the front panel of the device using a Phillips #1 screwdriver.
    • Remove the other 5mm screws that secure the charger port and the buttons to the inside of the front panel.
    • Remove the six 3 mm screws securing the battery clip.
  6. Vtech InnoTab 3S Speaker Replacement: passo 6, imagem 1 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Using the tweezers, remove one battery clip from each corner (four total) of the Vtech InnoTab 3s.
    • With the tweezers, unsecure the charging port, headphone port, and the light switch button from the front panel of the device.
    • Potential for device damage: Avoid forceful movements when removing the motherboard to prevent damage of device components.
  7. Vtech InnoTab 3S Speaker Replacement, Speaker: passo 7, imagem 1 %32 Vtech InnoTab 3S Speaker Replacement, Speaker: passo 7, imagem 2 %32
    • Looking at the front of the motherboard, the speakers are located in the bottom left of the device. They are shaped like a large black circle.
    • Using a soldering iron, heat the connections securing the speakers to the motherboard of the device.
    • Remove the connections on the motherboard to detach the speaker.
    • Avoid forceful movements when soldering to prevent damage of device components and avoid personal injury.
Conclusão
Uma outra pessoa concluiu este guia.
Equipe
USF Tampa, Team 8-2, Eyestone Fall 2015 Membro de USF Tampa, Team 8-2, Eyestone Fall 2015
USFT-EYESTONE-F15S8G2
Membros da 4
Autoria de 9 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 6
Duração total: 677
