Introdução
Headphones do not work when you plug them into the InnoTab? This guide will walk you through replacing the headphone port on your childs Vtech InnoTab 3S.
O que você precisa
While holding the battery compartment locks down, slide the two battery doors outwards from the sides of the device.
Remove the batteries from the device.
With tweezers remove the headphone port from its slot on the device.
Solder the wires securing the headphone port to the device.
