Introdução
In order to make repairs to the Vtech InnoTab 3 it is necessary to know how to safely dissamble the device. This guide is relatively easy and allows you to access the guts of the device. Before you begin, make sure you have a PH00 screwdriver and a metal spudger
O que você precisa
Slide the battery compartment door lock down.
While still holding the battery compartment lock down, slide the two battery doors outwards on either side of the device.
Carefully remove the batteries from the battery compartment.
