Ir para o conteúdo principal
Vornado Duo Fuse Replacement
O que você precisa
  1. Vornado Duo Fuse Replacement, Fuse: passo 1, imagem 1 %32
    • Grasp plug and remove from the receptacle or other outlet device.
    • Do not unplug by pulling on cord.
  2. Vornado Duo Fuse Replacement: passo 2, imagem 1 %32
    • Open fuse cover by sliding access cover on top of attachment plug.
  3. Vornado Duo Fuse Replacement: passo 3, imagem 1 %32
    Ferramenta utilizada nesse passo:
    Flathead 3/32" or 2.5 mm Screwdriver
    $5.49
    Comprar
    • Remove fuse carefully by gently prying out the ends of the fuse from the receptacle again using the driver with the 2mm flathead.
    • Risk of fire. Replace fuse only with 2.5 Amp, 125 Volt fuse.
  4. Vornado Duo Fuse Replacement: passo 4, imagem 1 %32
    • Install replacement fuse by first placing the end of the fuse into the fuse receptacle which is opposite of the blades of the plug, then carefully push in the other end. (Only push against the metal end of the fuse, not the glass center portion)
  5. Vornado Duo Fuse Replacement: passo 5, imagem 1 %32
    • Close the fuse access cover by sliding the cover back into the plug until it is completely closed, latches and is flush with the face of the plug. (Risk of fire. Do not replace attachment plug. Contains a safety device that should not be removed.)
Linha de Chegada
6 outras pessoas executaram este guia.
Tyler Pettenger
Membro desde: 09/28/17
536 Reputação
Autoria de 3 guias
Equipe
USF Tampa, Team S1-G1, Nance Fall 2017 Membro de USF Tampa, Team S1-G1, Nance Fall 2017
USFT-NANCE-F17S1G1
Membros da 3
Autoria de 4 guias
5 comentários
It’s still not working for me - I’ve cleaned the whole fan, put it back together and changed the fuse. Any tips? Thank you.
Whitney Sturner - Responder
Did you ever get an answer? I'm having the same problem
bysgamer617 - Responder
Probably a damaged circuit board capacitor, search out a micro-electronic repair shop. Or, authorized dealer. Often you can find a repair that understands multiple board systems and can easily test and repair your fan. An example, Apple technologies.
GW Roberts (GW) - Responder
Please remember, if you purchase the fan from any source other than an authorized dealership, who has invested money and training, the manufacturer has NO responsibility to that unauthorized purchase.
Is there “a tell” that the problem is the motor or circuit board before searching for fuses? For the 1st micro second it moves an inch like it’s getting power.
Djlaine17 - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 24
Últimos 30 dias: 107
Duração total: 14,965
