Ir para o conteúdo principal
Vornado 133 Compact Air Circulator Fuse Replacement
O que você precisa
  1. Vornado 133 Compact Air Circulator Fuse Replacement, Fuse: passo 1, imagem 1 %32
    • Ensure the unit is powered off and remove the plug from the outlet.
  2. Vornado 133 Compact Air Circulator Fuse Replacement: passo 2, imagem 1 %32 Vornado 133 Compact Air Circulator Fuse Replacement: passo 2, imagem 2 %32 Vornado 133 Compact Air Circulator Fuse Replacement: passo 2, imagem 3 %32
    • Slide open the fuse access cover on the top of the plug by moving it towards the end of the plug.
  3. Vornado 133 Compact Air Circulator Fuse Replacement: passo 3, imagem 1 %32 Vornado 133 Compact Air Circulator Fuse Replacement: passo 3, imagem 2 %32 Vornado 133 Compact Air Circulator Fuse Replacement: passo 3, imagem 3 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Use a pair of tweezers or a small plastic spudger to remove the fuse from the fuse casing. Remove the end nearer to the fan body first, then the end nearer to the plug end.
    • The replacement fuse must be 2.5 amp, 125 volt.
    • Do not push against the glass center of the fuse, only the metal end pieces.
Conclusão
Follow these instructions in reverse order to install the new fuse and close the access panel.
11 outras pessoas executaram este guia.
Erin Klein
Membro desde: 07/06/17
483 Reputação
Autoria de 3 guias
Equipe
UW Tacoma, Team S1-G2, Liner Summer 2017 Membro de UW Tacoma, Team S1-G2, Liner Summer 2017
UWT-LINER-SU17S1G2
Membros da 4
Autoria de 4 guias
10 comentários
Great post! This saved me $60 from buying a new fan! Thank you!
jamiekim808 - Responder
Thanks for posting. Ordered a pack of 50 fuses from amazon for $7.97
TLCIMMORTAL - Responder
Fast-acting or slow-acting?
James Olsen - Responder
Wow, I was going to throw this fan in trash and seeing your instructions I saved it
Anupam B - Responder
thanks buddy, just bought the fan ,son stuck a pencil in it , Quick fix
BOBBY C - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 26
Últimos 30 dias: 163
Duração total: 32,123
