Ir para o conteúdo principal
Voluas VL001 Main Drive Gear Replacement
O que você precisa
  1. Voluas VL001 Main Drive Gear Replacement, Storage Tank: passo 1, imagem 1 %32 Voluas VL001 Main Drive Gear Replacement, Storage Tank: passo 1, imagem 2 %32 Voluas VL001 Main Drive Gear Replacement, Storage Tank: passo 1, imagem 3 %32
    • Remove the lid to the storage tank by using the latch and lifting off.
    • Grab the food storage tank on both sides. Depress the tabs that say "Push" on them and lift the tank off.
  2. Voluas VL001 Main Drive Gear Replacement, Battery: passo 2, imagem 1 %32 Voluas VL001 Main Drive Gear Replacement, Battery: passo 2, imagem 2 %32 Voluas VL001 Main Drive Gear Replacement, Battery: passo 2, imagem 3 %32
    • Place your pet feeder upside down.
    • Squeeze the lock and remove the battery cover.
    • Remove the three 1.5V D alkaline batteries.
  3. Voluas VL001 Main Drive Gear Replacement, Housing: passo 3, imagem 1 %32 Voluas VL001 Main Drive Gear Replacement, Housing: passo 3, imagem 2 %32 Voluas VL001 Main Drive Gear Replacement, Housing: passo 3, imagem 3 %32
    • Insert a metal spudger under the adhesive part of each rubber foot.
    • Pry the foot off.
  4. Voluas VL001 Main Drive Gear Replacement: passo 4, imagem 1 %32 Voluas VL001 Main Drive Gear Replacement: passo 4, imagem 2 %32
    • Remove four screws from the corners of the device using a Phillips #2 screwdriver.
    • These holes were previously covered by the rubber feet.
    • Using the magnetic tip of the screwdriver, carefully lift the screw out of the hole.
  5. Voluas VL001 Main Drive Gear Replacement: passo 5, imagem 1 %32
    • Turn the device over so it is oriented right-side up.
    • Lift the top part of the feeder off, exposing the mechanisms that run the feeder.
  6. Voluas VL001 Main Drive Gear Replacement, Main Drive Gear: passo 6, imagem 1 %32 Voluas VL001 Main Drive Gear Replacement, Main Drive Gear: passo 6, imagem 2 %32 Voluas VL001 Main Drive Gear Replacement, Main Drive Gear: passo 6, imagem 3 %32
    • Remove the two 11 mm screws that attach the portion switch to the device using a #2 Phillips screwdriver.
  7. Voluas VL001 Main Drive Gear Replacement: passo 7, imagem 1 %32 Voluas VL001 Main Drive Gear Replacement: passo 7, imagem 2 %32
    • Using a Phillips #2 screwdriver, remove the single 13 mm screw that is found in the center of the main drive gear shaft.
  8. Voluas VL001 Main Drive Gear Replacement: passo 8, imagem 1 %32 Voluas VL001 Main Drive Gear Replacement: passo 8, imagem 2 %32 Voluas VL001 Main Drive Gear Replacement: passo 8, imagem 3 %32
    • Firmly grab the gear and remove it from the device.
Conclusão
Merari Aniga
Membro desde: 01/30/24
459 Reputação
Autoria de 4 guias
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 3
Duração total: 41
