Introdução
Maintaining the air quality inside your Volkswagen ID.3 is essential for a comfortable and healthy driving experience. One of the key components in ensuring clean air is the cabin air filter. Over time, this filter can become clogged with dust, pollen, and other pollutants, reducing its effectiveness. To keep your vehicle’s air fresh and clean, it’s recommended to replace the cabin air filter every 20,000 kilometers or once a year, ideally before springtime. This guide will walk you through the steps to replace the cabin air filter in your VW ID.3, ensuring you can breathe easy on every journey.
O que você precisa
Raise the hood by simultaneously lifting and pressing up on the hood latch release, located beneath the front edge of the hood, near the center.
Use one hand to hold the hood open temporarily while securing the hood with the prop rod:
Lift one end of the prop rod up or out to release it from the front area of the engine bay.
Swing the end of the prop rod up and slide it into the cutout on the underside of the hood.
Remove the cover by simultaneously pressing down on the release latch and pulling the cover left and out.
Remove the cabin air filter by pulling it out towards yourself.
To install the new filter, follow these instructions in reverse order.
