Introdução
Hello! This guide will show you how to replace the digitizer on your Vizio VTAB1008.
O que você precisa
Carefully slide the heavy duty opening tool between the gap on the side of the device with no buttons.
Corner tabs may require a more forceful prying tool. If needed, carefully insert the metal prying tool into corners to separate the tabs.
Quase terminado!
Conclusão
