Introdução
Over time, the Micro USB charging port may become worn out or defective. Here is a guide on how to replace this part. During step 1, take special care to the black ribbon as it can be easily damaged.
O que você precisa
Obtain the black plastic spudger tool from the iFixit toolkit. Position the device as shown in the picture. Insert the flat end of the spudger directly in the space above the power button between the back cover and front screen.
Ferramenta utilizada neste passo:Tweezers$4.99
Place the flat end of the black plastic spudger under the black plug and pry up to release the black ribbon. Using the metal tweezers, pull the black ribbon out of the plug.
